Massive voltage drop issue
Old Mar 28, 2020 | 12:26 AM
the_texas_bandit's Avatar
the_texas_bandit
Okay so I have recently replaced my starter on my 93' IDI non-turbo, and was able to get my truck to fire up, I let it idle for about an hour and then shut it off. After shut down I figured hey why not double check to make sure I have no other issues and try to start it up again. Went to fire it up and all I got is a bunch of clicks from the starter. I did a voltage drop check on both batteries and I found out as soon as I turn the key the voltage drops to 7.5 volts and it stays there til glow plugs click stuff the truck usually does is done, it goes back up to 12.8 volts. When the key turns to start position all I get is clicks from starter. Is that a glow plug issue itself or a relay or something else? I've been wanting to get this truck running strong for 2 weeks now and it's been one thing after another going wrong.
Old Mar 28, 2020 | 12:29 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
as I already said it sounds like weak batteries
Old Mar 28, 2020 | 12:34 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
charge em up with a good Maintenance charger on a low amp setting for a couple days and then see if it brings em back IF not then I say your Batteries no longer have a good storage capacity.
EDIT: sometimes you can desulfate batteries and bring em back to a serviceable life but that generally takes a month or 2 on the desulfator.
Old Mar 28, 2020 | 12:53 AM
the_texas_bandit
Yeah I like to get this truck up and running ASAP.
Old Mar 28, 2020 | 01:00 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
as I asked before... Fubared Starter Relay.... try jump the 2 large terminals and see if your starter works.
they can arc internal and then even when they click they don't make a good connection between the 2 large posts.
A remote starter switch is the proper tool to use For Safety ... but most folks use a screwdriver or a wrench.
Old Mar 28, 2020 | 07:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could also be a dead alternator.
Old Mar 29, 2020 | 04:46 PM
irhunter's Avatar
irhunter
I'd start by trying a jump start.
If it starts...check the voltage with the truck running.
Report back.
Old Mar 29, 2020 | 08:19 PM
DarkOverCast's Avatar
DarkOverCast
If alternator checks out I'd go get the batteries charged and load tested. Sounds like one or both might have a bad cell. Most auto parts stores do this for free although I'd recommend you but replacements from Walmart. 3/5 year warranty and they're cheaper!
Old Mar 29, 2020 | 08:27 PM
the_texas_bandit
I was able to jump it and get it started alternator is putting out around 14.2 volts batteries where charged up and tested. Both came out good. I did notice that if I wait on the glow plugs cycle the voltage goes back up. But my wait to start light kicks off way before it starts to cycle. And I am beginning to think something is up with my ignition system at the key cause the starter tried to engage when the motor was running.
Old Mar 29, 2020 | 08:29 PM
the_texas_bandit
Thats who I have the batteries through. Been buying there batteries ever since I turned 16 and was able to legally drive
fordzilla01
Dec 10, 2010 10:30 AM
THEDON117
Jan 28, 2010 04:06 PM
fordfinatic
Dec 15, 2009 08:59 AM
bockusd
19
Mar 30, 2009 09:07 AM
95psd
15
Feb 25, 2006 08:08 PM
