Trailer Safety Chains
Old Mar 19, 2020 | 06:02 AM
Brian Exline's Avatar
Brian Exline
The design of the hitch where the safety chains hook up is the only thing I dislike about my truck. What a crap design.
Old Mar 19, 2020 | 06:07 AM
CBANKS's Avatar
CBANKS
I second that statement
Old Mar 19, 2020 | 07:17 AM
Wildweasle86's Avatar
Wildweasle86
Blue locktite.
Originally Posted by ATC Crazy
Another 5/8 shackle user here. I tightened mine with some pliers so they don't back out, and to act as a theft deterrent. They don't rattle either...
I used some blue locktite on mine to prevent any backing out.
Old Mar 19, 2020 | 09:02 AM
Joe T's Avatar
Joe T
I think they are perfectly made for a 5/8 d ring shackle. Had to tap mine up some with a rubber mallet. They don’t slide around or make noise.
Amazon packs of 2 for under $20.
Old Mar 19, 2020 | 01:39 PM
SuperAlan's Avatar
SuperAlan
Goofy Chain Connection
Agreed. You'd think they would have this one figured out by now...
Old Mar 19, 2020 | 05:52 PM
ForCal's Avatar
ForCal
I thought I read that the 2020's have larger holes for the safety chain hooks.
Old Mar 19, 2020 | 06:32 PM
347Rider's Avatar
347Rider
2 Pack of 1/2" G80 Black Hammerlock Coupling Link Kits for Heavy Duty Truck Safety Chain Towing Hitch. Work great and look "clean" (or as "clean" as can be).
Old Mar 19, 2020 | 08:42 PM
TCNashville's Avatar
TCNashville
I went with the 5/8'' shackles for ease of removal. Just don't want em hanging there when they're not being used.
Old Mar 20, 2020 | 04:55 PM
Jimmy Pet's Avatar
Jimmy Pet
I see alot of you using shackles, but isnt anyone concerned that in a failure that the shackles would be needed to do their job the load path on the shackle is 90° to its designed load path?
It doesnt look to me that the shackle can rotate to have the load go through the bell > pin.
It looks like it would be forced to side load.
Now a 5/8 shackle probably has more headroom than might be needed, but I assume this has been discussed?
Old Mar 20, 2020 | 05:25 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Honestly, if I get into a situation bad enough to separate my trailer from my truck, I would rather it break free instead of dragging me wherever it wants to go. That's what the breakaway system is for.
Old Mar 20, 2020 | 06:02 PM
Jimmy Pet's Avatar
Jimmy Pet
I dont think thats how you want it to work. Well that may be how you want it to work, but I know its not how the DOT wants it to work.
It is 100% supposed to keep the trailer attached in some way to the tow vehicle so it does not go careening away at speed and hit someone or something.
I actually know (knew) of someone here in my area (a local Dr) who died "because" a trailer brokeaway. I dont remember the exact forensics, that it had no chains or insufficient chains but the trailer broke away, and it crossed the median and impacted his vehicle head on killing the driver.
I tried to search it but I think it was a bit before the internet, the Dr was a friend of my Uncles. I know the trailer puller was prosecuted and civilly sued as well.
Something like this: https://www.mankatofreepress.com/new...d00e2a0f2.html
And this: https://www.witn.com/content/news/Dr...563724141.html
Its 100% supposed to keep it attached to the tow vehicle.
Old Mar 20, 2020 | 10:16 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I know how it's "supposed" to work.
My shackles will keep the trailer hooked to my truck if it pops off under normal driving.
They will most likely break if I'm in a rollover situation. At that point, it doesn't really matter IMO
And both of my shackles together are rated at ~175% of my trailers GVWR, and ~225% of my truck's operating weight.
Old Mar 21, 2020 | 07:35 AM
  #28
jbrnigan's Avatar
jbrnigan
I suspect the "weld" holding the chains to the trailer tongue would fail, or the chain "break" before the shackle would fail in a catastrophic "disconnect". Hope to never find out. But, of all the "safety" concerns associated with pulling a 5 tons of travel trailer down the road, safety chain, shackle failure, is way down my list.
Old Mar 24, 2020 | 02:09 PM
  #29
jollyrogr's Avatar
jollyrogr
This is a 2020 hitch. It looks like the holes might be slightly larger? They measure 3-1/8” x 1-5/8”.
Old Mar 28, 2020 | 11:08 AM
  #30
Frank79's Avatar
Frank79
Bought these 5/8" stainless shackles from Amazon. Marine grade 316SS, so they wont rust. $24 each.
