Cam help
here is what I have so far for my motor.
TF 195 72cc heads
Holley SA 670 carb
Edelbrock manifold
FK water pump
Cloyes timing chain
every ARP bolt or stud I can find
gonna use TMeyer pistons
the 3 cam options I’m considering are
Comp XE274H
Comp 268H
or a custom grind from a MPG
any advice on a cam would be appreciated thanks
https://www.ford-trucks.com/forums/1...shoot-out.html
With regards to their cams billets, I highly suspect that they are also using Chinese & they do not include Parkerizing their cams unless you want to pay extra for it (Parkerizing is the final step and a crucial step to help break the cam in- a heated acid bath that microscopically etches the metal surface and adds a very thin layer of graphite coating which allows the cam lube to hang onto and penetrate into the cam surface during cam break in) unless you specifically request and pay additional money for it. Some will swear by their Comp Cam and when I have spoken and inquired with them I have found in most cases the cam is cut on Comps 8620 core (copper colored base) which runs $400+. But the typical MacD production cam has a silver / metal camshaft made from the cheaper 5150 cores that won't last 20K miles before wiping out and failing.
This is a not so unusual posting about Comp and their components…..
http://forums.vintage-mustang.com/vi...-camshaft.html
Considering the cam has such critical importance to the engines performance and life, to me it makes sense to use a cam grinder who will talk with you directly- even modify the cam grind to fit your needs even better and to address the possibility of cam lobe failure with the new oils. When it comes to making an engine breathe, there are so many variables including elevation, humidity, fuel blends/available octane, most cam mfgs will vary a "core grind pattern" to match the external impactors in addition to the internal impactors- which today IMHO makes the different between and engine that runs well, to one that just seems to run a little bit better, smoother and gets better mileage than expected.
With regards to price...the difference is nil- especially considering its cheap insurance to know exactly who is machining such a critical part for your engine. And remember, advertized lift/duration/lobe separation is just that- advertized and not the specific grind including ramp profile that is used on the cam. Which is why you can take to cams with the same lift/duration (nearly) from 2 different cam grinders and each will perform differently. Also, avoid Eddy cams like the plague.... they really have nothing as far as design goes that's really good or really bad, its just ok from a performance standpoint but QA.... is back to where they were in the mid 80's when the place darn near closed it's doors as far as the cams go.... you couldn't get me to put one of their cams in any of my engines....lobe specs off as much as .060 has been reported.
I highly recommend Iskenderian (who I personally know to this day physically tests/inspects every single valve spring before it leaves the shop) & Crower & Chet Herbert & Lunati...all are family owned, been grinding cams for decades, and both will even re-grind your oem cam if possible- saving you even more $.
I don't want to beat the Comp Cam QA issue to death, but here are just a few examples to validate the “McDonald’s environment” of which operate:
Tech Support Issue:
Fuel Pump Rebuild
Valvetrain Failure:
Classic Cam Failure:
http://www.hotrodders.com/forum/more...ure-48577.html
Cam Lobe Fracturing:
http://www.yellowbullet.com/forum/showthread.php?t=458553
Cam Failure:
http://www.camaros.net/forums/showthread.php?t=121078
FAIL Comp cams trunion- Rockwell hardness low:
http://www.corvetteforum.com/forums/...n-upgrade.html
2nd Cam Failure:
http://www.performanceboats.com/gn7-...p-failure.html
Major problems with Comp Cams hydraulic roller lifters :
COMP CAMS FAIL (endless)
http://truestreetcars.com/forums/gen...cams-fail.html
Comp Cams Ultra Gold Aluminum Roller Rocker Failure
http://www.ls1gto.com/forums/showthread.php?t=388981
Comp Cams 918 spring failures
http://www.camaroz28.com/forums/ls1-...ilures-526319/
Cam Failure:
http://www.camaro5.com/forums/showthread.php?t=389981
