400 cam ideas needed
Old Jun 3, 2003 | 12:41 PM
rogue69's Avatar
rogue69
I have a 79 bronco with 35s and 410 gears. the engine is a 400 with an edlebrock intake and a 625 cfm 4 bbl carb. I plan on using the bronco for mudding and want to add a better cam and roller timing chain. Any ideas on what cam to use? I would think that a larger cam would be a good idea for mudding. Any idea of horse power gains.
Old Jun 3, 2003 | 05:13 PM
rogue69's Avatar
rogue69
test
Old Jun 4, 2003 | 09:39 AM
GT40man's Avatar
GT40man
cloyes true roller timing chain, and um what cam is in it now.
Old Jun 4, 2003 | 11:22 AM
rogue69's Avatar
rogue69
I dont know what cam is in it. I just bought it and would guess it is stock or maby a rv cam. Do you know any prices for these parts?
Old Jun 5, 2003 | 08:19 AM
GT40man's Avatar
GT40man
http://www.pawinc.com/cataloginfo.html
this place has the best prices on cams, and has a good selection as well.
this is a start.
Old Jun 6, 2003 | 11:16 AM
rogue69's Avatar
rogue69
Thanks gt40man
Old Jun 6, 2003 | 05:37 PM
Coondawg's Avatar
Coondawg
Comp Cams makes cam kits (K-kits) that have everything you need. Cam, lifters, springs, retainers, locks, and roller chain. Any good supplier will be able to hook you up.
I mention this because it is a good idea to match the springs and cam.
Old Jun 6, 2003 | 08:26 PM
Ecuri's Avatar
Ecuri
Coondawg is right on track. I have been running their RV cam (273 adv duration .500 lift) for years and am very happy with it. The increased lift means you must buy new springs also or risk (like 99%) coil bind. This has been a very reliable cam for me and really perks the engine up. Can't estimate HP gain, but is substantial. This cam is designed for the lower RPM bands which I assume is where you will be doing most of your running.
