Need a cam kit??
Old Feb 15, 2016 | 01:43 PM
my-ford's Avatar
my-ford
Need a cam kit??
So my cam is wiped out.78 400 6.6
I'm really not sure what kind to get or what brand.I would really like a roller cam and lifters. so I don't have to worry about braking it in that bad.
I'm not looking to build a drag truck.but I would like to get the most I can out of it. with out braking the bank.
I'm hoping I can get a full kit.camshaft,lifters,push rods,and timing gears and chain.
I would love your guys input on this.thanks.....
Old Feb 15, 2016 | 01:49 PM
hivoltj's Avatar
hivoltj
Howard's cams makes link bar roller lifters. They can be had for around $350 if you shop around. Need more info on your combo but is usually recommend Howard's small mild roller or something from the comp Xtreme energy line.
If u wiped a cam lobe you need to take a look at the bearings
Probably looking at around $800 for cam, lifters, timing chain and valve spring set
Old Feb 15, 2016 | 02:03 PM
my-ford's Avatar
my-ford
I was hoping someone offers a full kit.because I don't knowto do the math on compression ratio
I'm going to take it all apart and have the block inspected.it has a oiling problem.the bearings are making a bad sound. I'm replacing everything except the crank and pistons
Old Feb 15, 2016 | 02:10 PM
hivoltj's Avatar
hivoltj
Tim Meyer can set you straight. If you have a stock 400, the best budget build is a stock rebuild with tim's 9.5:1 pistons. I run his grooved cam bearings and oiling modifications as well. I had access to a cheap set of Aussie Cleveland heads so I went that route which makes for about 10:1
Old Feb 15, 2016 | 04:19 PM
my-ford's Avatar
my-ford
Angry
I'm not sure what all was done to the motor.I know it was a fresh rebuild.the pistons are stock.I think it may already have a big cam I never could get the lope out of it. Do aftermarket cams have brand names stamped on them or anything like that.so I can find out what it has already?
dimora
176
Apr 26, 2018 08:00 PM
72fordgts
Nov 6, 2014 01:49 AM
4wheeling79
Sep 21, 2011 03:21 PM
TheBlueMule
Apr 8, 2008 09:42 AM
78bigbronco
Jul 31, 2006 08:33 AM
