2020 Camera/TPMS/Backup Sensor Cable Problem
#61
Picked the truck up Wednesday night, spent the day today installing firestone airbags, just in case. I also installed the rear wheel well liner but I think I should have installed the Duraflap mud flaps first, since it appears that I need to remove a bolt that is now behind the liner. It was getting late so I decided to put everything away and work on it over the weekend. Tomorrow morning I'm dropping it off to have the chip protection 3M film applied to the front bumper, entire hood, front fenders, lights, mirrors, A-pillers (hopefully reduce swirl marks on the gloss black), door handle cups, door edges, front of rear fenders, and rear bumper as well as having the front door windows tinted to match the back.
Now, as far as the trailer TMPS, no kit provided at all, dealer says probably 2 week, we'll see. The only thing provided was the trailer yaw sensor for the back up assist. It came in a clear plastic zip lock with part number LC3T-14G621-AC. I pointed out that when the order was made it was listed as only 50 dollars and now the PO says 500. Salesman didn't remember our conversations of course, but he did get my 1-2-2020 expiration date $2500 PCO locked in and an additional $500 dollar incentive that is no longer available on Platinums locked in as well that I didn't know about so I decided to drop the argument over the 50 vs 500. It was a big check to write though, base price x-plan with all my options 85,346.43 + 4,981.18 WA state sales tax - 3000 PCO/insentive = YIKES!
Truck is great though.
Yes on the sticker shock, sales tax is even higher in CA and DMV fees really add up.. I had to write a 6-figure check for my truck, even with my trade. But I love the new truck - it's only money and you can't take it with you
#63
Hey MH, can you do me a favor? Can you look under your hood and see if there is a rubber like filler piece on one side or both sides. It's above the head light between the front top edge of the fender and the hole where the air intake is for the air filter. My truck only has it on the passenger side and I'm wondering if they forgot to install it on the drivers side or if its only supposed to be on one side, seems like it should be on both. thanks
#64
I noticed on Nichols having a "12-Pin harness for Back Up Assist, TPMS & Trailer Camera System". Is this what is needed to use Trailer Camera and backup assist at same time?
https://nicholsmanufacturingandweldi...camera-sysytem
#65
I now have a tracking number for the new Ford kit that my dealer is sending me. I expect to have it on Monday.
#66
#67
#68
perfect Thanks MH. That's the same as my F450. the only thing I can think is that they are trying to keep water from running along the fender and then wrapping around into the air intake area. Blocking/diverting it with the rubber piece to force it to drip off behind the air intake.
#69
#70
The price for this harness is $180.00 if you mail us your two Ford harnesses.
The price for this harness is $570.00 if you do not supply us with the two Ford harnesses.
If you send us the two Ford harnesses after you receive your new custom harness we will refund you the difference of $390.00 ($180 for the Y-harness & $210.00 for the Back up Assist Harness)
It appears that the two Ford harnesses cost about $390 and they are charging you $180 to disassemble them and combine the parts. It probably takes a special tool to remove the Backup Assist Harness pins from the 12-pin connector and press them into the empty holes in the camera/TPMS Y-harness 12-pin connector. From my observations, there are only 2 pins for the Backup Assist cable. So you would be paying $180 for the convenience and probably less than 1 hour of labor. Based on the prices they quote for the harnesses, I would guess that the new Ford harness would be more than $200, maybe $250-$300 as it will have 4 connectors. The price for the new Backup Assist Harness seams high as it only has two connectors vs. three on the Y-harness and there are only 2 wires in the harness.
Good luck with getting Ford to pay for this, but if your dealer values you as a customer, maybe they would pay for it. After all sold you the truck and these are not cheap trucks.
#71
As I understand the $375 camera is dealer supplied, does not ship with it but dealer provides...
Did not option the camera but bought it on line from a Ford dealer for $288...installed it last week. Short write up and pics of camera pics...love it, but love more if accessed while driving.
https://www.ford-trucks.com/forums/1...arrives-3.html. Post 88
https://navtv.com/products/NTV-KIT910/cod-f53.html
there is an fte discount . (I got 1/2 off)..
see https://www.ford-trucks.com/forums/1...l#post19095872
#72
I added this kit to my 18, which gives cameras while in motion, including trailer cam
#73
#74
New Camera/TPMS kit received
Well, the good news is that the package from my dealer arrived today via UPS in a snow storm.
The bad news is that it is the same kit that I received before, the 2017-19 kit without the backup assist module connection on the harness.
I sent the dealer an email with this info. It looks like the Nichols harness may be the only current solution. Stay tuned for his reply...
