DPF cleaning?
Old Feb 10, 2020 | 10:40 AM
  #61
Overkill2's Avatar
Overkill2
Originally Posted by FishOnOne
My truck has a little over 180k miles +5k hours, +1k idle hours and my DPF/EGR hasn't been touched. As a matter of fact my fuel economy has slightly increased and I've been running ExxonMobil Diesel Efficient fuel exclusively for the past year that produces less soot and that can only help the emissions system. This small increase in fuel economy is compared to when my truck was new so that tells me my dpf is not clogging to the point if affects performance and fuel economy. I drive a mixed city and highway and pull occasionally.
I just started using Mobil Synergy fuel. It seems like my truck passive regens faster. Like more reduction than before. Time will tell. I'm on my 3rd tank I believe.
Originally Posted by Work Truck Fanatic
Do you disable auto regen manually? If not how do you get the truck to bypass the 500 mile limit between regens?
Check out this thread.
Old Feb 10, 2020 | 09:36 PM
  #62
Work Truck Fanatic's Avatar
Work Truck Fanatic
Originally Posted by senix
running of premium 50 cetane fuel. But that is only at home, on the road it is at truck stops like everyone else.
Your tag says you are in Fredrick, MD. I travel through there occasionally. If you don't mind which stations carry premium fuel?
  #63
Work Truck Fanatic
Will do thanks
Old Feb 11, 2020 | 05:08 AM
  #64
senix's Avatar
senix
Southern States on Route 85. They have truck lanes. Todays price is $2.66 a gallon.
Old Feb 12, 2020 | 08:16 AM
  #65
The Bone's Avatar
The Bone
Why not take your truck to the dealer and have them solve the problem. Sometimes it's cheaper to have the dealer fix something than guess at what might be the problem.
Old Mar 28, 2023 | 12:33 PM
  #66
Overkill2's Avatar
Overkill2
Originally Posted by BertMerdec
Hi there! It's great to see that you're taking such an active approach to monitoring and maintaining your DPF.
Hey there... This thread is 3 years old. But I've done this myself... Who knows, maybe it will gain traction.
Old Mar 31, 2023 | 02:31 PM
  #67
The Bone's Avatar
The Bone
Personally I don't know if a DPF would be worth cleaning if it had a lot of miles. I am not sure how long they are supposed to last.
Old Mar 31, 2023 | 02:45 PM
  #68
senix's Avatar
senix
napa sells some stuff from Lucas for cleaning the DPF.
Life is hard to really pin down. There are many over 200K miles.
Old Mar 31, 2023 | 03:00 PM
  #69
Overkill2's Avatar
Overkill2
I use this every tank. Since I don't have a bed cover that could keep stuff secure in the bed, I keep this in a military ammo can in the truck that has a seal on it because this schitt stinks.
https://pittsburghpower.com/pages/max-mileage
Pittsburgh Power also cleans DPFs using the equipment from DPF Alternative's. They cut the rocketship open to get to the particulate filter part I believe. They have articles on this on their site as I believe I've seen it on the Ford's systems before.
https://pittsburghpower.com/pages/dpf-alternatives-1
I have seen kits online that make the DPF part of the rocketship a bolt on after it's separated from the whole body.
Dstosh
Feb 18, 2011 06:41 PM
Fungus232
Jun 9, 2009 09:31 PM
ottawaguy
Mar 3, 2009 10:21 PM
CaliFordDood
Nov 9, 2008 07:19 PM
worldbarefootrec
1983 - 2012 Ranger & B-Series
Aug 19, 2007 10:05 PM
