Sponsored by: Real Truck
Force regen enabled in IDS
Old May 6, 2016 | 12:06 PM
mtiffee's Avatar
mtiffee
I had ford reprogram my tank size to 50 gal after my Titan install. I also had them enable force regen which enables a gauge that shows filter %. Does anyone know how to activate the manual regen now? I heard the screen would enable you to do so once it shows full. It's now full but doesn't have an option to start a regen.
Here's the gauge:
Old May 8, 2016 | 11:42 PM
34SF's Avatar
34SF
So what the secret? My dealer says it's impossible.
Old May 9, 2016 | 06:20 AM
mtiffee's Avatar
mtiffee
I'm guessing that enabling "forced regeneration request" in IDS only activates that gauge. I don't see anyway to do a operator commanded regen. Either way, it's nice to see that gauge. When they activated it, I was at 95%. Later that day it said FULL and when I hit the freeway it started the regen. You can watch the gauge go down every 5%. Kinda nice, not sure why that's not activated by default.
Old May 9, 2016 | 07:24 AM
scraprat's Avatar
scraprat
Top Answer: 5
What you have is just the screen to show %. Can't do a manual regen.
Old Feb 9, 2020 | 09:53 AM
harleyjoeky's Avatar
harleyjoeky
Old tread, but I had my 2012 programmed (actually did it myself with Forscan's free windows download. It works fine, but will only let you do a manual regenerate once it reaches 85% or over. Perhaps your dealer didn't program it correctly. IT'S NOT IMPOSSIBLE.
Old Feb 9, 2020 | 10:17 AM
mtiffee's Avatar
mtiffee
What happens that enables you to manually do it? Does an option appear on that filter % page?
Old Feb 9, 2020 | 10:20 AM
harleyjoeky
Nothing happens.. If you check your % on that page and see that it's above 85, you can then just press ok to clean it (as per instructions on the screen). If it's not over 85, then there will be no option to regain. Remember that you have to be sitting still in Park to be able to activate the manual regenerate. It takes about 15 minutes and loud as hell.
Old Feb 9, 2020 | 10:59 AM
Overkill2's Avatar
Overkill2
So you're saying by enabling the 3rd ghost screen to show the DPF soot load %, that in itself will enable the truck to do a manual regen as long as the soot load is 85% or higher? And all that has to be done is press the "OK" button and follow the directions on the gauge screen?
Old Feb 9, 2020 | 11:15 AM
harleyjoeky
That is correct. You'll have to press the ok button and hold it for it to start.
Old Feb 9, 2020 | 11:30 AM
Just Strokin's Avatar
Just Strokin
It seems that after the 2012 models (only one known 2015 can do it), Ford doesn't give any messages about performing a manual regen. I have tried it and never seen any messages on my 2015. I am the one who posted the photos of the IDS enabling of the Exhaust Filter screen.
Dave, there is only one known case of a 2015 Lariat being able to do the manual regen. No one else has been able.
I also thought it had to be 95% or higher to do it.
Old Feb 9, 2020 | 11:31 AM
Overkill2's Avatar
Overkill2
Thanks. I appreciate your response. Are you over in that FORScan thread that Larry, Just Strokin', started? I've perused it before but that's a lot of pages to go through. I've been wanting to activate my factory DPF Soot Load % screen for awhile now. This is great. Not that I need it but it's great to know it's there in case I had to. So this will work for all the 11 to 16s, do you know?
*EDIT
Okay, I see the FORScan master has answered. That bites.
Old Feb 9, 2020 | 11:54 AM
ehagerty's Avatar
ehagerty
I can't get the screen on my 2011 Lariat, as many time I set it it get overridden
Old Feb 9, 2020 | 01:47 PM
Overkill2's Avatar
Overkill2
I saw your response after I posted mine. Thank you Larry.
Old Feb 9, 2020 | 02:45 PM
Just Strokin
Search this thread in the 6.7 forum. Keith might be able to help you.
FORScan and As-Built Data - Ford Truck Enthusiasts Forums
Old Feb 10, 2020 | 03:58 AM
ehagerty's Avatar
ehagerty
Thanks Larry,
Been thru that whole thread and some others. From what i have learned is I can turn on forced regen but I cannot get the screen on the dash. he OEM coding over rides it...i have read where others have experienced this. I will read thru it once again incase i missed something
