P0404 and P0405
Old Feb 17, 2011 | 10:52 PM
Dstosh's Avatar
Dstosh
P0404 and P0405
My truck has been throwing a cel for the last week or so. It has always been P0405. I cleared it once and it came back only a few hours later.
So I dug into it today and removed the egr and it was super dirty. Its the first time i've pulled it in the 50,000 miles that I owned the truck. ( I know I know)
The egr was filthy as imagined. See picture. I looked in the hole where the egr goes and it was also full of carbon and soot etc etc. What causes this and how can I clean it? I know it cant be good.
Thanks
Old Feb 18, 2011 | 11:40 AM
steelhead2's Avatar
steelhead2
you can use carb cleaner on the egr valve,but dont use brake clean on it.unless youre going to remove and clean the intake man. i wouldnt disturb anything in there.what ever you dislodge and cant get out is going to end up in the cylinders.you could try to vacuum it out with a shop vac i suppose, but youll never get it clean without removing the manifold.all that stuff is from the egr system.
Old Feb 18, 2011 | 11:57 AM
gearloose1's Avatar
gearloose1
1. If you have not pulled it ever, it may be a legacy problem that dates from bad fuel years back. 2. Clean it, and it may never come back dirty again. 3. Consider buying a brand new EGR valve from the dealer or Partsguyed.com If you do not have EGR valve testing capabilities, that make sure you got one that does not have a electrical fault. 4. Give it a real good Italian tuneup to blow carbon out of system for next few weeks... once a week. 5. Clear codes I would disconnect the batteries and do a system reset at same time.
Old Feb 18, 2011 | 06:01 PM
cheezit's Avatar
cheezit
cleaning a valve with a p0405 is a waste of time. the a coil is shorted or shorting out. its an internal malfunction.
Old Feb 18, 2011 | 06:39 PM
Dstosh's Avatar
Dstosh
Ok. Ill have to pick up a new one. From what I have read..one with a pink dot on top is the updated one?
Thanks for the info
Old Feb 18, 2011 | 06:41 PM
gearloose1's Avatar
gearloose1
Thanks for the info
Don't get one from a no name / ebay source.
Get one from a dealer or partsguyed.com
There are a lot of "reman" or cleaned parts out there.
Don't risk it.
Old Cheeze has spoken.
Brad Wissinger
Nov 26, 2016 07:52 AM
Dstosh
Sep 28, 2016 03:18 PM
Freskan6.0
Sep 7, 2015 12:03 PM
F250_6.7
Sep 1, 2015 05:29 AM
Dstosh
Feb 4, 2009 11:31 PM
