The old dodge was a 12v so I guess it was 95-97. It has the 8 on 6.5 pattern but I'm running dodge wheels on the inside cause they run on the hub. There's 4 inch spacers to get the inners out from the springs then 3 inch spacers to seperate the duals. Ford wheels on outside
That s A LOT of spacer. Why not just run dodge dually pickup 80 and have no 4" spacer
Well the thinking was that the shorter shafts of the c&c axle would be a little bit stronger and not so much twist and spring back. I was breaking alot of stuff and was trying to be as strong as possible.
Kind of.. I did break a stock Dana 80 35 spline shaft then I upgraded to chromoly. Then I broke the spider gears. But then I put in too big of injector and the truck got soft and then the season was over. So it kinda worked.
