Hey guys, I have a 93 F350 7.3IDI 4x4. it's single rear wheel, and I'd like to make it a dually. I have access to a DRW axle from a 1992 F350 Rwd truck. Can I just pull parts from the axle donor or is it a full swap? Your help is greatly appreciated
Okay, it's a dually with a bed. It's a 2wd. So I'll have to grab from hubs off a 4x4 dually elsewhere. Does anyone know if the 2wd dually front wheels will fit 4x4 hubs?
Yes, the wheels will fit but they have a different offset 2wd to 4wd
Okay so I have works out a deal for the rear axle and wheels. But I wanted to get your guys opinions. It's coming from a 2wd pickup so the back spacer will be less. Is it worth waiting to find a set from a 4wd or is it not a big deal. I know I'm gonna want to fit tires that are at least 4wd oe or little bigger if that's possible. Also I read somewhere else to make sure the rear axle has VSS, what is that and will a 1992 axle have it? thanks fellas!
I just grabbed a front 4X4 hub for my dually from a wrecker in NH called P&L auto...less than $100 shipped to CA. I know hes got one left. I used car-parts.com to locate the hub and there were several other vendors with them available. Good luck!
