Oil filter relocation.
Old Jan 2, 2020 | 05:40 PM
PRIMERED79 SHORT BED's Avatar
I have a 92 f150 4wd and was wanting to relocate the oil filter for ease of access when doing oil changes.
If anybody has done it what kit did you use and were you able to locate it in a more accessible area?
Thanks.
Old Jan 2, 2020 | 10:19 PM
Briansshop's Avatar
Briansshop
I used a block adapter and filter mount from Canton Racing, https://www.cantonracingproducts.com/
Not cheap,but nice stuff. You can get some cast cheaper stuff from Trans-dapt, https://www.hedman.com/Trans-Dapt-Performance
Mine not typical,for sure. Had to remote mount it for room to run the turbo piping. It was way easier to get at compared to on the block reaching though the cross member.
Mounted here with stock Twin I Beam
And here with the Crown Vic
Old Jan 3, 2020 | 08:42 AM
Freightrain's Avatar
Freightrain
I've used remote kits also, mine was a Transdapt from nearly 30 yrs ago. Use QUALITY hoses!!! You don't want to leave yourself stranded due to a blown hose because it was a cheap hose/fittings.
AV8ER
Mar 8, 2010 07:45 AM
pounder90
Mar 10, 2005 07:15 AM
Randyb12
Mar 16, 2004 10:32 PM
jwcnj45
Jan 19, 2004 03:38 PM
ickeskartom
Oil & Lubrication
Jun 2, 2003 10:19 AM
