Pretty frustrated, trying to swap joints before it snows (tomorrow) bench vice broke, had to return and re-order joints..... anyways, on my 2001 f250 4x4, I believe the procedure to tightening the joint nuts on the axle housing is tighten the lower joint to 35 feet pounds, tighten the top but to 69-70 feet pounds, then tightening the bottom to 150 feet pounds.. my torque wrench feels way off and is very cheap... so I tuned it to the proper specs and went through the tightening procedures and the knuckle is very snug... will this change after the break in period??
in summary of my questions:
1: are my torque specs and procedures correct
2: why is the knuckle tight to turn by hand
3: are digital torque wrenches reliable
No your numbers sound right from what I recall. 35 bottom, 69 top then either 101 or 150 bottom depending which ball joints/year. I don't think an extra 50 ft lbs would stop them from moving, the only part that spins is the ball inside the joint. They shouldn't be loose to turn, should be snug, it should take some muscle to move them. They'll move a lot easier once the wheels are on and you have some mass to push them.
Your numbers are good and no re-torque necessary. Done this job a few times. I took my knuckles to a my local guy to press out the old ones and press in new ones....for $20 a side, I couldn't pass it up.
