Reybestos ball joint torque
Old Jan 29, 2013 | 09:06 PM
vczar1's Avatar
vczar1
I'm going to install a Raybestos professional grade ball joints on my 2002 7.3 Ex. I can't find torque requirements anywhere, instructions say it has to be proper but does not say what is proper. Does anyone know?
Old Jan 29, 2013 | 09:07 PM
Papa Tiger's Avatar
Papa Tiger
I would go with OEM specs or call M.
Old Jan 29, 2013 | 09:11 PM
vczar1's Avatar
vczar1
What is the OEM spec?
Old Jan 30, 2013 | 12:01 AM
Kdr358's Avatar
Kdr358
Big breaker bar and brute force
Upper ball joint nut to 101 lb-ft. Same for the lower
Old Jan 30, 2013 | 01:57 AM
jrproper's Avatar
jrproper
I just did this two weeks ago..
The torque sequence should be:
35 ft-lbs lower,
70 ft-lbs upper,
then re-torque lower to 190 ft-lbs
Old Jan 30, 2013 | 02:48 AM
Papa Tiger's Avatar
Papa Tiger
Is 190 a typo? 110?
Old Jan 30, 2013 | 03:00 AM
jrproper's Avatar
jrproper
Originally Posted by Papa Tiger
Is 190 a typo? 110?
No typo.. 190 per the instrutions that came with the ball joints and the vid I included in the above post. Basicly as tight as you can get using a 18" breaker bar... pressing my foot on the spring for a bit of leverage and keeping in mind I'm not the stongest guy.
Old Jan 30, 2013 | 09:56 AM
double ott ex's Avatar
double ott ex
here is the procedure I followed when I did mine.
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
DOE
Old Jan 30, 2013 | 10:46 AM
Kdr358's Avatar
Kdr358
This is why I never mess with tq specs. Call me old school but I have enough experience to tell when something is tight. The only time I torque anything is if its steel into aluminum.
rbfunk85
May 22, 2023 03:13 PM
Whitey Ford
May 9, 2015 08:55 AM
Rus01
Oct 28, 2010 09:47 AM
mason346
Apr 12, 2008 04:46 AM
Plowdude
Aug 9, 2006 10:17 PM
