Engine Block Number Decoding?
Old Oct 22, 2019 | 01:56 PM
hardbuilt's Avatar
hardbuilt
Anyone know how to decode this?
We are trying to figure out what oil and oil filter to buy...
Old Oct 22, 2019 | 02:48 PM
seville009's Avatar
seville009
Many threads....here’s one that might help
https://www.ford-trucks.com/forums/5...ck-number.html
Old Oct 22, 2019 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
[/Q
This is hard to read, is it E7TE? If so, this would be 1987, but I don't know the engine size because casting numbers cannot be cross referenced to Ford part numbers.
Old Oct 22, 2019 | 04:57 PM
hardbuilt's Avatar
hardbuilt
I see
28
ETTE
SA
S
No idea what that means. I have the transmission and differential to decode as well. Is there a spot on the engine to verify the size? We are pretty sure it’s a 302
Old Oct 22, 2019 | 05:13 PM
NumberDummy
I see
28 // ETTE // SA // S
It cannot be ETTE, because the 2nd digit is a number.
It's probably E1TE-SA 1981 truck or E7TE-SA 1987 truck, possibly a 302 or 351W
Old Oct 22, 2019 | 05:17 PM
hardbuilt's Avatar
hardbuilt
Great thank you. Is there a way I can confirm now if it’s the 81 or the 87?
Here are pictures for ID
Old Oct 22, 2019 | 05:40 PM
66v8baby's Avatar
66v8baby
Ford changed the firing order of the 302 in '82, so if it is 1-5-4-2-6-3-7-8 it is an '81. If it has the Windsor firing order, 1-3-7-2-6-5-4-8 it is at least an '82 or later. Also note that Ford changed the imbalance from 28 oz to 50 oz in '81, so you need to use a harmonic balancer and flywheel/flexplate with the later 50 oz imbalance. The firing order is cast into the top of the intake manifold. It looks like an '81 to me.
Old Oct 22, 2019 | 06:24 PM
g4g2g7's Avatar
g4g2g7
it’s a 302, so back to your original question about filter & oil...don’t overthink it, just get a motorcraft FL1A (or equivalent from another brand) and put 10W40 in it.
Cyrusjohn
Jan 30, 2017 11:05 AM
Redworks
Jun 21, 2015 08:02 AM
Sunburnt
Aug 31, 2006 04:55 PM
StevensPoint
Sep 30, 2004 10:45 PM
rmcgraw351
Dec 4, 2003 11:42 PM
