identifying engine year
Old Dec 3, 2003 | 03:05 PM
rmcgraw351's Avatar
rmcgraw351
Question identifying engine year
Is there a way to tell what year an engine is? Is there a de-coder or something that a person could use to translate the casting numbers on a block?
Thanks,
Ron
Old Dec 3, 2003 | 03:52 PM
fordman428's Avatar
fordman428
yes what are the castings on your block, i have a book i can look them up in, on my block on the passenger side there is a casting D3TE, that means it was made in the 70's C means 60's, but there are also othe castinfs by the oil filter adapter to, just find the castings and post back ill take a look in my book.
Old Dec 3, 2003 | 04:21 PM
rmcgraw351's Avatar
rmcgraw351
Hey Thanks Fordman!
I didnt look by the oil filter, but the numbers on the passenger side rear of the block are: D1VE-6015-A2B
If that doesnt do it, I will look for the numbers by the oil filter on friday and post again.
Thanks Again
Ron
Old Dec 3, 2003 | 05:56 PM
fordman428's Avatar
fordman428
i may need the castings by the oil filter for that i cant find them in my book.
Old Dec 3, 2003 | 06:03 PM
fordman428's Avatar
fordman428
oh nevermind i read your post of you castings wrong your block is a 1971, the rest of the #'s u posted are parts #'s, looks like you have an original engne in your truck, good luck.
Old Dec 3, 2003 | 06:05 PM
rmcgraw351's Avatar
rmcgraw351
THANKS FORDMAN!!
Old Dec 3, 2003 | 06:20 PM
fordman428's Avatar
fordman428
no problem thats what we are all here for.
Old Dec 3, 2003 | 10:14 PM
MuchToMyDelight's Avatar
MuchToMyDelight
on V8's, its easier to look at the casting numbers on the intake (if original) than finding them on the block. Just for future refrence.
Old Dec 3, 2003 | 10:28 PM
Mil1ion's Avatar
Mil1ion
That engine was designed in 1971 & it is a 460 .
It could have come out of a car or truck.
It was originally designed for the Lincoln.(V)
Casting numbers are also on the Heads,Intake,Exhaust manifolds.
Get me the other casting digits & I can tell you when it was cast .
This will tell me which year of vehicle that engine was put in.
See the bottom of this photo.
That's what you are looking for.
Old Dec 4, 2003 | 05:02 AM
willowbilly3's Avatar
willowbilly3
Where di you guys get that book? I want one
Old Dec 4, 2003 | 08:11 PM
boneman01's Avatar
boneman01
Can anyone give me a particular location on the head or block on a 300 6-cylinder to start scraping grease off to look for casting numbers? Manifolds are no good since I had to have them swapped out. Thanks.
Old Dec 4, 2003 | 09:13 PM
BB's Avatar
BB
D1VE-A2B is a '71 - '78 460 block, you need to find the date code to zero it in. 460's didn't come stock until '74 so it's a swap for sure.
Barry
Old Dec 4, 2003 | 11:42 PM
Mil1ion's Avatar
Mil1ion
On a 460, the head casting numbers are just below the sparkplugs .
The date code is under the valve cover in the oil galley.
RE: The block
Just up the side of the block above the starter.
Intake:
On top .Near the firing order casting
