Sponsored by: Real Truck
Speedometer is off, how to fix?
Old Oct 23, 2019 | 01:55 PM
saratoga2011's Avatar
saratoga2011
Originally Posted by rvpuller
Changing the wheel diameter will throw off the odometer that's right on when checked with GPS, l need a way to reposition the needle.
Denny
No, it doesn't. I've verified it. Does not set a CEL either.
Old Oct 23, 2019 | 07:11 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
How could it not change the actual miles traveled when changing the tire diameter.
Denny
Old Oct 23, 2019 | 08:36 PM
saratoga2011
Denny
Using that logic, how could the speedo be 3 mph off and the odo work correctly to begin with?
Again, I've adjusted the tire size and checked speed and distance; numerous others have done the same thing and confirmed it as well. Indicated speed agrees with the GPS and the odo indicates the correct distance over a 200 mile trip I took.
You should try it instead of disputing everything. Worst thing that happens is you end up restoring the as-built configuration with your stock settings.
Old Oct 23, 2019 | 09:07 PM
rvpuller's Avatar
rvpuller
The speedometer is off because the indicator is in the wrong position, you can tell because its off at 10 mph and 65 mph the same 2 mph.
If you keep the same tire and tell the computer that it has a different rolling diameter it will throw off odometer because of the distance the tire covers with each revolution.
Denny
cjspack
6.7L Power Stroke Diesel
16
Feb 17, 2012 03:35 PM
flrp
May 25, 2009 09:38 PM
pinball rescue
Jul 18, 2008 11:59 AM
Drone Leader
Sep 15, 2005 08:55 AM
muligan
Feb 28, 2002 12:16 PM
