Speedometer reading off a little
Old Feb 17, 2012 | 06:43 AM
cjspack's Avatar
cjspack
Has anybody else with the new 6.7 ('11 or '12) Super Duty noticed the speedometer is off a little? When my speedo registers 70 mph, my GPS indicates 67 or 68. BTW, everything on my truck is stock.
Old Feb 17, 2012 | 06:52 AM
JCU Delt Ox's Avatar
JCU Delt Ox
You'll find that damn near every make and model from the factory indicates a little higher than the true speed, some more than others.
Old Feb 17, 2012 | 08:32 AM
dschuffert's Avatar
dschuffert
Mine shows the same thing. Any vehicle I have done this comparison too is similar. In fact, I have seen different variances as you go through different speed ranges. When I am in the 0 to 30 MPH range my GPS and truck speedo are the same. They start diverting above 30 MPH in my scenario.
Old Feb 17, 2012 | 08:45 AM
Glockin' Bob's Avatar
Glockin' Bob
How's the odometer? If the odo is fast by a similar amount you'd be losing 2400 miles or so of powertrain warranty assuming you hit the mileage before the time limit.
Old Feb 17, 2012 | 08:57 AM
chperry's Avatar
chperry
My speedometer is off by around 3mph consistently when compared to my Garmin. It reads high. I was concerned about the odometer and checked it on round trip from Knoxville, TN to Charlotte, NC (around 500 miles). The odometer and the Garmin agreed within a few tenths of a mile! Therefore it appears the truck knows how fast it is really moving and purposely displays a lower value.
Old Feb 17, 2012 | 09:02 AM
AlexWV's Avatar
AlexWV
It's the other way around. If your speedometer is reading high (says you are going faster than you really are), your odometer is reading low (says you are going fewer miles than you really are).
Mine is 2% off as determined by me via careful observation with GPS.
When odometer says I have gone 100 miles, I have in fact gone 102 miles.
When I hit 100,000 miles, I will have 2,000 free warranty miles on the engine.
Old Feb 17, 2012 | 09:12 AM
cjspack's Avatar
cjspack
Thanks for the verifications/observations guys. I'm sure the manufacturers have a motive for this because I'm also sure they could get it right if they really wanted to. But in the end, I guess it's really no big deal.
Old Feb 17, 2012 | 09:19 AM
dschuffert's Avatar
dschuffert
That is a very good point, I have never thought of that aspect before. I'll have to measure that, although I am not sure how accurate my measurements would be.
Old Feb 17, 2012 | 09:33 AM
Adobe 11SD's Avatar
Adobe 11SD
I read a similar thread last year and someone (maybe it was Epic) posted that the government required the speedometer variance. There was a document attached, but I don't remember if it was regulated by the State or Federal government. I thought that it had something to do with speeding tickets.
I think that all vehicles have this "variance" built in to some degree. Then again, I have slept since then and that thread may have been a dream.
Old Feb 17, 2012 | 10:01 AM
kper05's Avatar
kper05
The odometer should be correct because the truck actually knows how fast it's going, it just reports it 2-3 mph faster to you on the gauge.
If you put your truck in engineering mode and scroll until you find the speed screen, you'll find it's very close to a good GPS within the tenths decimal place.
Old Feb 17, 2012 | 10:31 AM
jack_pine's Avatar
jack_pine
I remember posts about engineering mode, but forgot. How do you get there?
Old Feb 17, 2012 | 10:37 AM
CascadeF250's Avatar
CascadeF250
My GPS reads one mile per hour slower than the truck speedometer. At 70 MPH by truck-- GPS says 69.
Old Feb 17, 2012 | 11:26 AM
los341's Avatar
los341
It is the mechanical speedometer that reads fast. The truck knows how fast it's actually going as indicated in engineering mode. That's why the odometer is relatively accuarate as well. Yes, said it's a law that the speedometer can never be "slow" or the manufacturer will face a fine.
With that being said, is there a way to tweak the mechanical speedometer to display the correct speed? I swear mine reads at least 10% fast.
Old Feb 17, 2012 | 12:40 PM
Glockin' Bob
You might wish to double check your arithmetic. If a speedometer is indicating fast, likely so is the odometer.
The more your tires wear, the faster your speedometer will indicate for a given speed. Additionally, those tires will spin more revolutions per mile due to the decreased circumference so more "ticks" per mile will accumulate, hence the odometer will become faster with the speedometer. If you put oversize tires on the vehicle without recalibrating the speedometer for those oversize tires, both the speedometer and odometer will be "slow".
If you're checking your odometer using a GPS device over the course of 100 miles, a GPS will overstate the distance traveled due to the sampling nature of the device. The sampling and inherent accuracy causes the straight line path you've actually traveled to be a slight "sawtooth". The cumulative distance of this sawtooth (think roughly 15 meters) causes the device to slightly overstate straight line distances.
Old Feb 17, 2012 | 02:20 PM
TheKid1's Avatar
TheKid1
Sounds like your GPS receiver is sloppy
