78 not starting until key is released.
Old Oct 19, 2019 | 12:35 AM
fordatic's Avatar
fordatic
My 78 F150, the brown one won't start. I was driving it daily and parked it for a couple weels. I went drive it one day and it won't start. However when i release the key it fires and cuts off. why am i getting fire only when releasing the key? I changed solenoid, ignition module, and key switch assembly? only other thing i can think of is the distributor, but that doesn't make any sense to me why it would cause that. Any ideas??
Old Oct 19, 2019 | 06:41 AM
fordguy2100's Avatar
fordguy2100
Have any mice been feasting on some ground wires?
Old Oct 19, 2019 | 08:46 AM
4x4slik's Avatar
4x4slik
First question, had you messed with any wiring prior to it not running proper. It sounds like you are not getting power, or enough power to your magic pixie making circuit. I would defiantly check and clean all grounds, add a few if you haven't already, and replace any factory ones that are missing. The 3 main are from battery to engine, from engine to frame, from engine to cab. Clean the contact area for your duraspark. If that doesn't work, you need to start testing. Putting a meter on the power going to the duraspark and see if you have proper voltage during start.
Old Oct 19, 2019 | 09:21 AM
Olblack's Avatar
Olblack
Hello 4x4 , could you please explain how to test the duraspark.
Old Oct 19, 2019 | 09:31 AM
4x4slik's Avatar
4x4slik
Well, in this instance you need to probe the power going into the duraspark. You would be looking for voltage drop during the starting period.
Old Oct 19, 2019 | 09:45 AM
fitzmotor's Avatar
fitzmotor
That sounds like the ignition switch, disable the start circuit (pull the small wire off the starter solenoid) turn the key to the run position and check for voltage at the coil, you should have voltage there, then turn the key to the start position, see if you still have voltage at the coil, if not it's the ignition switch.
Old Oct 19, 2019 | 09:48 AM
440 sixpack's Avatar
440 sixpack
I agree the ignition switch is most likely the problem, or a wire from it. if that's not it the pick up coil can cause this , I had it happen.
Old Oct 19, 2019 | 09:51 AM
4x4slik's Avatar
4x4slik
I think when he said he changed the key switch assembly he meant he changed the ignition switch, but I could be wrong.
Old Oct 19, 2019 | 09:54 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is some talk about it. But who has an oscilloscope now days? Dura Spark II
Some out of the manual troubleshooting of the DSII scroll down just a bit
https://www.ford-trucks.com/forums/1...l#post17700315
Here is a walk thru and some troubleshooting And an excerpt from it below.
https://www.ford-trucks.com/forums/1...l#post14880906
Note the part about from the above link " Often times, if the pickup fails (which is what you're checking), it will not switch the module while the engine is cranking, but letting off the key collapses the coil, which gives that final spark. If the BLINK test BLINKs, then my test is a moot point."
Old Oct 20, 2019 | 02:00 AM
fordatic's Avatar
fordatic
no evidence of any.
Old Oct 20, 2019 | 02:02 AM
fordatic's Avatar
fordatic
no prior wiring done. the grounds mentioned are in place, but may check to make sure making ground.
Old Oct 20, 2019 | 02:03 AM
fordatic's Avatar
fordatic
already replaced switch
Old Oct 20, 2019 | 11:51 AM
Creston's Avatar
Creston
Everytime I've had this happen, it's been the pickup coil. Others mentioned it as well. I have seen it many times. My wood hauling truck just did the same thing this year. The distributor (and therefore pickup) was only a couple months old on that particular truck. They will usually run a while then die. Then wont start, only firing when the key is let go. Then later will start and repeat the process. Sometimes the coils check bad with an ohmmeter. Sometimes not
bronkntrukholik
Feb 10, 2014 02:57 PM
Aftrmidnite
1997 - 2003 F150
Dec 27, 2013 11:03 AM
sailorman1952
62
Dec 18, 2006 04:40 PM
coplin
Sep 11, 2004 04:05 PM
Peter Nikols
1997 - 2003 F150
Dec 4, 2003 05:20 PM
