I joined this site for the sole purpose of finding help for my truck problem. if you guys can coach me, i will be eternally in debt.
2 days ago on the way home, my 1976 f-150 just died on the road as if the key had been turned off. since then, it will crank and start as long as i have the key in the crank position. as soon as i release the key it dies. i replaced the soleniod yesterday and it still won't stay running after i start it and release the key. today i replaced the ignition switch. still the same. somebody please help me figure this out. i have to work in the morning and i need my truck! it is not the battery, it cranks and starts just fine. it just won't stay running after the key returns to the on position. it looses all spark.
Hey Dennis, thanks for answering so fast... let me print your response out and give this a try. No, i did not replace the key tumbler, just the casing with all the contacts. i never would have dreamed the non-electric tumbler assembly could possibly be the problem.
I'll report back after i try your suggestions
Jack
Hey Dennis, I put a test light on the top coil post and it has juice in the run position. In fact, it has juice in all positions except the off position.
I never installed the key tumbler assemby in the new ignition. I am sticking a screwdriver in the new ignition switch and operating it like that.
Any thoughts?
Jack
lol! In fact I did see it, however I'm not that good if can't get a '76 truck started.
The nub at the end of the tumbler is pristine. looks like it just came from the factory. I don't have a way to take a pic of it, but believe me, it's like new, just like the photo you sent. I'm stymied on this... haven't got a clue what the problem is.
Yes it starts just fine, it just won't stay running when i release the ignition and it falls back to the "run" position. As long as I leave it in "start", which makes the starter bendix grind while it's running, it runs just fine. It's only when I let the spring-loaded mechanism in the ignition switch go back to the "run" position is when it dies like the key has been turned off. Weird, huh?
Hey Dennis, please don't tell me you gave up. I'm in a pile of crap here and I really need expert advise. If you are as perplexed as I am, perhaps you can refer me to someone?? My cell number is 972-898-1918. Actually, this is a friend's number who is here now trying to help me with this. I'm too broke to have a phone.. that's why I drive a '76 truck that won't run now.
Holy Moly, I think I found the problem. Let me run this by you and let me know what you think... the prove out diagram you sent says that the ignition switch casing should be grounded. I don't have it grounded, I have it just swinging free under the dash because it is so hard to take in and out of its mounting spot on the dash. perhaps if I ground the switch it might work. What do you think?
