Sponsored by: Auxito
New Transponder key
Old Dec 4, 2003 | 05:18 PM
Peter Nikols's Avatar
Peter Nikols
New Transponder key
Hello,
I recently bought a new tronsponder key. I had it cut at a local key shop. It opens doors, but when I went to program it, I discovered that the key won't turn in the ignition. It is just jammed.
I emailed the guy who sold me the key and he sais it wasn't cut right. He said I need to gently pull it out as I'm turning the ignition to the run position so that I can find the right position.
I was wondering if it might be something in the tronsponder. Does it jam up the key if it's the wrong transponder or something like that?
Any advice would help.
Peter...
Old Dec 4, 2003 | 05:20 PM
emtabmm's Avatar
emtabmm
no, if the transponder is bad the engine will just not start, the actual key cuts is what is jammimg the ignition cylinder....
