Hey guys. I have a 75 f250 with dual piston calipers up front. I noticed I didn't have much lining on my pads so I changed them. (Disappointed to find that the Raybestos pads I ordered showed rivets holding pads to backing, but came with the lining material filling the voids once occupied by the rivets, as though lining is cast onto backing plate!) Anyway, I clamped the pistons into the calipers on the truck, bolted the pads in place, and away I went.
I did notice that the rotors had deep grooves, but they've been like that forever. There was not an issue with the old pads.
With the new pads the right side pads drag and make a crunching kind of sound when I brake. I'm thinking the rotors need to be turned or replaced, and the calipers could use a rebuild since it's been 8+ years since that was done. I've had the truck since ...96, and the rotors have never been turned.
I'm curious as to why it was fine with the thin pads, and now why only one side is a problem.
It's possible the caliper pistons are rusted where they were outside of the quad seal, and when you pressed em back in the rust bound the pistons up in the quad seal where they can't retract. Also possible that the hose has failed internally, but not likely since it wasn't a problem prior to the pad replacement. I suspect the noise is related the the caliper sticking. First thing I like to check in a situation like that, I jack up the offending wheel, see how much resistance there is to turning the rotor, then crack the bleeder. If the resistance goes away, its the hose. If the resistance remains, its the caliper.
The hoses were changed 6 months back. Today I should be able to dig into the problem. I have a rebuild kit for the calipers. I guess it's time for me to rebuild them. It is nearly impossible to find replacements for the rubber rings that the mounting bolts ride in. Oh well ...
1975 F250 The hoses were changed 6 months back. Today I should be able to dig into the problem. I have a rebuild kit for the calipers. I guess it's time for me to rebuild them.
Well I had another crack at the front right caliper--the one that was dragging. I removed the caliper and rebuilt it, cleaned off the pistons (dual) with 1000 grit sand paper. One piston was locked. I had to heat it, melt the seal, to remove it. I also had to remove and clean with emery cloth the slider pins/bolts. I also found that I had a spare set of front hoses, so I threw those on too.
I see that Rock Auto has the hardware kit with the rubber bushings that the slide/bolts/pins ride on. They also have the pistons, seals, pins, etc. They sell the rotors for half what the parts houses sell them for, and charge only $18 shipping. That's a savings of $50 each.
Back in the day (88-90) I used to rebuild the rear cylinders on my 75. This time my son and I figured we would just get new (cylinders and calipers) and use the time saved on other repairs. Sometimes I think we undervalue our time on some repairs.
Yep, I still prefer steel in this application. But the phenolic models were there primarily (I think?) to get rid of the chance of rusting and sticking in the bore. But then some early ones got hot and cocked off at an angle or warped, so not such a great idea.
But if they're still using them, I guess they've over come the usual early shortcomings. Hopefully...
But I still like steel.
I well remember using a hone on the wheel cylinder bores and rebuilding them. Eventually I too went to buying new or rebuild w.cylinders. I have now been using disc rears for about ten years, together with hydro boost. It is one of the best mods I have done. The brakes are fearless. I recently converted to parking brake calipers in the rear, and I love them. Good luck.
I used a phenolic carb spacer for a while. It cracked and broke. I would not want to risk that with caliper pistons. That is scary imo.
