Sponsored by: Auxito
Won't Start, PATS??
Old Oct 23, 2013 | 04:47 PM
Aftrmidnite's Avatar
Aftrmidnite
Won't Start, PATS??
It doesn't do this all the time. The Engine cranks over fine, but won't start. When it does start everything is okay and it runs good with no codes. I noticed that by taking the key out of the ignition, I was checking under the hood, and put it back in the truck fired right up. Also it has never done this to the second driver who has a different key. The truck runs fine at all speeds and loads, even when hauling twenty bags of wet mulch. It's a 2001, 4.6 L, RWD. Could the PATS Chip be failing?
Old Oct 23, 2013 | 04:59 PM
Spotty's Avatar
Spotty
I would say your key is funky if the other key always works. As long as 2 keys still work I would buy a 3rd key and program in before your key is totally shot. You need 2 working keys to program it at home, otherwise you will need a locksmith with a clone machine or the stealer...good luck!
Old Oct 23, 2013 | 05:44 PM
projectSHO89's Avatar
projectSHO89
If the THEFT light is fast-flashing during a failed starting attempt, it's a PATS issue.
If it isn't fast-flashing, then it's not PATS.
Get the observation right to avoid wild goose chases.
Old Oct 23, 2013 | 08:27 PM
Aftrmidnite
Well it's not the key, did it tonight on the second key. It does it intermentatly, then when it starts everything is normal. I well watch the Theft Light more closely.
Old Oct 23, 2013 | 09:15 PM
projectSHO89
About this time, I'd be hooking up a fuel pressure gauge with a long hose and watch the fuel pressure each time. Your symptoms are of a lazy fuel pump that's getting ready to quit but that's not the only possibility.
While you're watching the cluster for the THEFT light, also observe the check engine (Service Engine) light and, if you have a digital odometer, what the odometer is doing during failed vs. successful starting attempts.
Old Oct 23, 2013 | 10:29 PM
steve(ill)'s Avatar
steve(ill)
this sounds stupid, but i have one key that will start the truck in one positons, but if i pull the key out and turn in over and put back in, it will not start.... does it all the time !!!!!!!
Old Oct 24, 2013 | 05:49 AM
projectSHO89
Define "will not start".
Old Dec 26, 2013 | 09:12 PM
Aftrmidnite
I checked the fuel rail pressure and it was correct. I changed the Fuel Filter and the problem went away. Two weeks ago it was back, I'd put the pressure gauge on and it would start right up. Had the pressure regulator checked. Today I was at the dealer trying to get a switch, and it just wouldn't start. Turns out the Fuel pump had a dead spot on the armature. I'll get the truck back tomorrow. Thing drove me nuts, truck couldn't have picked a better spot to act a up.
Old Dec 27, 2013 | 06:57 AM
Spotty's Avatar
Spotty
Bad fuel pump eh....glad you found it. It always amazes that an armature in the fuel pump is arcing and tossing sparks and never blows up. I suppose with no oxygen the sparks are useless.
Old Dec 27, 2013 | 11:03 AM
projectSHO89
Gasoline will only combust with a specific fuel/air ratio which is not present in the fuel tank.
Aug 3, 2024 05:36 PM
Firefighter 1406
19
Mar 26, 2011 01:21 PM
jayram75
Feb 18, 2009 11:11 AM
04expo80f250
Dec 15, 2007 03:33 PM
KWest
Apr 16, 2006 12:26 PM
