Injector Replacement Not Working
Oct 17, 2019 | 07:14 PM
Hard to read since all the data is in one column, but that data looks ok.
Edit - That will certainly set a code (EBP unplugged)
I would keep an eye on the alternator output.
Oct 17, 2019 | 07:15 PM
I would have batteries load tested separately.
My alternator runs around 13.2 to 13.5. When I first turn motor on it struggles around 12.7 because of the draw from glow plugs.
Oct 17, 2019 | 07:17 PM
Re-reading the data- I don't see your volts coming up when the engine starts.
Oct 17, 2019 | 07:19 PM
this time psi
Thank you all, a very big help.
Yeah, EBP sensor may have gotten unplugged when I did the blue spring. ha. who knows.
Oct 18, 2019 | 05:29 AM
My Forscan drive to work this morning. about 10 min of 40mph with a few red lights followed by 5 minutes of 70mph.
Oct 18, 2019 | 04:24 PM
In post #12 he posted a BAD ICPV value at KOEO
OEM SPEC is .18-.24v @KOEO IIRC
HE had 259 psi ICP witg only a key on NOT RUNNING this would be bust
im lost. Truck runs ok now?
Oct 18, 2019 | 04:34 PM
Quote:
Originally Posted by
BLADE35
sorry, had it it ka not psi.
Truck is running fine now and the only explanation is an 18hr charge at 6amps. Alternator seems to be ok
Oct 18, 2019 | 04:35 PM
Oct 18, 2019 | 05:34 PM
J. D. Herridge
Hey no worries just glad your back up and running
It was ICP VOLTS @ KOEO that was out spec in post 12 but your last pic of. Gauge shows spot on ICPVOLTS @ .24V. @KOEO Just so we on same page
mxcatman
6.7L Power Stroke Diesel
Sep 7, 2018 03:05 PM
RockinFord
Dec 12, 2011 05:58 PM
Dunatic
Aug 11, 2011 03:06 PM
ramsay
Apr 29, 2011 11:54 PM
fordfast
Mar 16, 2005 05:19 PM
