Injector Replacement Not Working
Old Oct 16, 2019 | 07:08 PM
J. D. Herridge's Avatar
J. D. Herridge
Originally Posted by mattdoc88
Bubble test is a quicker version. Just pull the upper fuel filter and crank with the wire by the fender and see if you get bubbles. If so, and you can't tell which side they're coming from, do the balloon method to determine which head the bubbles are coming from, then pull glow plugs to identity the problem cylinder.
No bubbles in bubble test. That means? no air in fuel ? and not what he was describing above?
Old Oct 16, 2019 | 07:19 PM
J. D. Herridge
There were no bubbles during bubble test.
Old Oct 17, 2019 | 04:24 PM
J. D. Herridge
New code via forscan!
P2617 - Crankshaft Position Output Circuit / Open
Old Oct 17, 2019 | 04:43 PM
J. D. Herridge
for scans read today.
Old Oct 17, 2019 | 05:20 PM
bismic's Avatar
bismic
Cranking data for:
FICM VPower and FICM LPower?
ICP pressure, ICP voltage, IPR % duty cycle?
Cranking rpms?
v-reference voltage?
Old Oct 17, 2019 | 05:24 PM
J. D. Herridge
Sorry for all of the updates. Just ran my truck for 30 consecutive minutes for the first time since all of this started without issues except when, while driving not in park, after quick RPM reduction a sucking/gasping sound under the hood. The only thing I did was give it about a 18hr 6amp battery charge.....I'm terrible at trouble shooting so I cant explain or understand.
Old Oct 17, 2019 | 05:27 PM
bismic's Avatar
bismic
Extremely low voltage can cause issues
Low cranking rpm can cause a no-start
Glad you got it started, but you may still have an underlying issue. Maybe the alternator isn't charging the batteries very well ..... who knows.
Looks like you still have an EBP code (sensor, wiring, connector)
For that, start with posting EBP, MAP, and Baro (all in the same pressure units), at KOEO.
Old Oct 17, 2019 | 05:47 PM
Visurveyor's Avatar
Visurveyor
Ok that's all good for dtc's. Get into dashboard and set up your pids.
As Bismic said you need:
Ficm v/m/l
Icp. Preasure/duty/volts.
Rpm crank
You know the drill.
You need to set up your Dash. You will then me able to monitor and Diagnose.
Old Oct 17, 2019 | 06:42 PM
Visurveyor's Avatar
Visurveyor
Forscan screen.
Torque Pro screen.
I went out and fired mine up to give an idea what you will see. Torque is a little easier to set up but forscan grows on ya the more you use it.
I run Torque for my everyday monitoring. That's just my preference. When it comes to detailed diagnostics I'm all Forscan.
Old Oct 17, 2019 | 06:53 PM
J. D. Herridge
first few seconds are crank
Old Oct 17, 2019 | 06:55 PM
J. D. Herridge
another crank.
Old Oct 17, 2019 | 07:05 PM
Visurveyor's Avatar
Visurveyor
I'll have to get on my laptop to view them csv.files. my super phone won't see them. But I'll look at them.
I'm glad you got it started. Now you can diagnose a little easier.
Old Oct 17, 2019 | 07:07 PM
  #28
J. D. Herridge
EBP sensor was just replaced in early august. the expensive oem
Old Oct 17, 2019 | 07:11 PM
  #29
J. D. Herridge
EBP sensor was unplugged, codes are gone.
But I believe there is under lying issue unless the deep charge is the fix.... maybe need to test alternator like previously suggested.
Any other ideas?
  #30
Visurveyor's Avatar
Visurveyor
I would switch my readings from kpa to psi. It simplifies what every one is looking at.
