Sync 3 Map updates
Old Sep 29, 2019 | 01:23 PM
  #61
morgaj1's Avatar
morgaj1
I got the download, but failed to get the license file. When I go back in under my VIN and ESN, it shows only the $40 USB option. Any ideas?
Old Sep 29, 2019 | 07:46 PM
  #62
DISLTom's Avatar
DISLTom
Originally Posted by Sport45
I used a 32GB stick for my update. Worked fine, the files take up 13.2G of space.
I didn't have any large USB stick handy. So I used a 256GB SSD in a SATA->USB3 portable converter.
Worked like a champ. No issues so far.
Old Oct 2, 2019 | 11:12 AM
  #63
Beast2.0's Avatar
Beast2.0
Does anyone know if the truck can be driven while the update is downloading or does it need to be stationary?
Old Oct 2, 2019 | 11:17 AM
  #64
hwheeler's Avatar
hwheeler
It can be driven. I just did it.
Old Oct 2, 2019 | 11:29 AM
  #65
Beast2.0's Avatar
Beast2.0
Thanks, much appreciated
Old Oct 3, 2019 | 01:21 PM
  #66
Rutcutter's Avatar
Rutcutter
Do you have to pay for this map update?
Old Oct 3, 2019 | 01:40 PM
  #67
Beast2.0's Avatar
Beast2.0
I believe that 2018 and up is free and 2017 is around $100. If you go to the link for the update,( https://syncnavigation.com/ford/home ) enter VIN and radio esn#, it will give you your options.
Old Oct 3, 2019 | 06:03 PM
  #68
leejk's Avatar
leejk
My 2018 F-350 was free.
Old Oct 3, 2019 | 08:42 PM
  #69
Rutcutter's Avatar
Rutcutter
It's been giving me an error code (016) an to contact customer service.
Old Dec 18, 2019 | 11:53 AM
  #70
LEMII's Avatar
LEMII
I have successfully connected the truck (2019 F-250 purchased on 11/30/2019) to my home wifi; I've turned on the Automatic Updates feature inside my Sync3 system. I get a rotating circle graphic and text stating it is searching for available updates. However, it never stops! The Ford.com guy I was chatting with wasn't any help - told me my Sync3 had the latest version and build. I still have problems with Waze showing a speed about 10 mph higher than the truck's speedometer when I use it via Apple CarPlay. Funny thing is, it works fine when NOT plugged in. I also tried my wife's iPhone and it did the same thing. We tried it in her 2019 Subaru Ascent with Apple CarPlay and it works flawlessly.
I've read that updating the Sync3 will fix this issue, but Ford is telling me an update doesn't exist for my truck....annoying!
Anyone have suggestions on how to update the software (not just the map) correctly?
Old Dec 18, 2019 | 11:58 AM
  #71
BocaIvan's Avatar
BocaIvan
Same thing happens with mine when searching for update.
2019, bought in April.
Old Dec 18, 2019 | 04:36 PM
  #72
GABAR's Avatar
GABAR
Updates are sent out to owners randomly so just keep checking.
Yes, other owners of the same year and model of your vehicle might have received said update already but all owners don’t receive the update at the same time and I think the reasoning for this is to stop the system from crashing because of everyone downloading and uploading at the same time.
Ford / SYNC learned this lesson back in 2017.
Also, WiFi updates are not the most reliable but they do work for some owners.
Old Jan 13, 2020 | 05:23 PM
  #73
MikeMB's Avatar
MikeMB
Keith,...
I have a quick question about the number of files created on the USB when you download the file. I downloaded the free upgrade and had the files setup on a USB drive. Other than the fact it took ages to get the files, and the instructions were rather vague on the number of files downloaded and when unzipped. I want to make sure I didn't miss any files.
MODERATOR'S NOTE:
EXERCISE CAUTION PRIOR TO CLICKING ON LINKS. LINKS ARE NOT VETTED OR VERIFIED BY FTE.
The domain "call24.com" suggests an answering service business in California. This is not a Ford Motor Company domain.
I contacted Ford@call24.com, and they don't answer any questions about downloads.
this are the the files on my USB, are the similar to these:
SyncMyRide (file folder)
autoinstall.lst
dontindx.msa
and inside the SyncMyRide file folder
7 .TAR file extension files
does this number of files look correct to you. I hope so anyway. Next step takes an hour in the Truck to install.
Thanks
Mike
function12
2009 - 2014 F150
Sep 25, 2019 05:42 AM
igotoneforya
May 1, 2013 12:24 PM
Lance250
Mar 13, 2010 09:33 AM
arctic y block
Jan 3, 2007 07:10 PM
mxz600ho
Feb 18, 2006 02:24 AM
