Vin Decode Please
Old Jan 3, 2007 | 08:48 AM
arctic y block's Avatar
arctic y block
Vin Decode Please
I believe It to be a 64 step side. Haven't got the engine numbers yet. That I can do with the sheets I printed from Johns site if I can find them. Mama cleaned up my desk and that's about as bad as letting someone use your shop. Anyway here's the Vin#FI0CE568190. Make sense to ya. Thanks
Old Jan 3, 2007 | 09:08 AM
mtflat's Avatar
mtflat
Ken's working on one for this site. I didn't run your's but heres the link:
https://www.ford-trucks.com/vin-decoder/index.php
Old Jan 3, 2007 | 09:10 AM
jowilker's Avatar
jowilker
FTE Vin decoder
FTE has recently added a site decoder https://www.ford-trucks.com/vin-decoder/index.php
Check it out, hope it works for you
John
Old Jan 3, 2007 | 09:39 AM
arctic y block
I tried the link several times and all I get is the ad. Something to do with the IE7 upgrade. No spam blockers or virus software running except IE7 and I have it turned down as far as I can. So no It dose not work for me. jowilker or mtflat can you or anyone decipher it for me please. If I could get into it I wouldn't ask. Thanks guys. Here it is again. Vin#F10CE568190
Old Jan 3, 2007 | 10:46 AM
jowilker's Avatar
jowilker
I am runing Firefox, and opened IE7 and it worked fine for me. Start a thread in the feedback forum that you can't use it.
Here are the results of running your number.
Ford Trucks VIN Decoder
Enter your VIN number:
Your VIN number: F10CE568190
Your Model Year is July 1964.
Truck Series: F100 2 Wheel Drive
Engine: 2V - 292cid, 135 HP, 3800 RPM
Assembly on: Manwah
John
Old Jan 3, 2007 | 11:05 AM
arctic y block
Thanks John. I find I have trouble in opening personal galleries and the like. I Got a smoking home built sys. But do need to reformat or just run fdisk and start all over. Don't think FTE is the problem. Thanks again for the vin John.
Old Jan 3, 2007 | 01:46 PM
jowilker's Avatar
jowilker
I have opened the link with Firefox, Opera, IE7, and Netscape. My conclusion is, it aint FTE.
John
Old Jan 3, 2007 | 05:30 PM
arctic y block
Ya John. I am sure it is my system. In the next few days I will hook up one of by back up systems and repartition this one. Reload Software and put her back on line and WIFI the two together so Mama and the Boys can do there own thing online or off. Would like to run another OS like Linux or something on a separate drive or partition. I know that this is the wrong forum for this. But as we are on the subject. What OS other than MS XP would you recommend? I am well familiar with DOS and can wright batch files and Boot programs in Any Windows environment. This should help in setting up a new OS. Thanks Again.
Tricky
Old Jan 3, 2007 | 05:44 PM
chadwickma's Avatar
chadwickma
Should break down like this:
FI0 C E 568190
F10 - F100 - 2 Wheel Drive
C - V8 - 292CID - 2B Carb
E - Assembly Plant - Mahwah, NJ
568190 - Consecutive Serial Number
Source: http://www.lmctruck.com/icatalog/fb_asp/0011.asp
Old Jan 3, 2007 | 07:10 PM
arctic y block
We got it. Thanks guys
Tricky
61 uni
Oct 7, 2012 08:20 PM
Noah2010
6.7L Power Stroke Diesel
Dec 10, 2010 11:50 AM
ynkstr
New Member Introductions
Mar 28, 2008 02:49 AM
tojaho
Oct 19, 2003 02:03 PM
trouble
Aug 17, 2002 11:41 PM
