FICM issue
Old Aug 24, 2019 | 05:26 PM
reverendxlt's Avatar
reverendxlt
FICM issue
Had a no start issue recently. Turned out both batteries were not good, so I replaced them. Figured the no start was FICM related, so I replaced the power supply.
In the meantime, ordered a scan gauge. Reinstalled FICM, scan gauge reading 0.00 for main power and 5.5-6 for logic power.
I think it's likely a grounding issue... but any other ideas?
Old Aug 24, 2019 | 06:48 PM
SmackDaddy's Avatar
SmackDaddy
Your FICM could be toast, it’s a symptom of cranking too much with low voltage.
Old Aug 24, 2019 | 07:52 PM
reverendxlt
Well, I likely did that... crap .
Old Aug 25, 2019 | 03:26 AM
bismic's Avatar
bismic
Send it to FICMrepair.com. No need to buy a new one.
Old Aug 25, 2019 | 04:35 AM
Yahiko's Avatar
Yahiko
While it's out take the alternator and have it bench tested.
Bad alternator can also cause FICM and Battery damage.
Old Aug 25, 2019 | 01:40 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
I agree with Sean - please get the alternator bench tested. When it is being tested, please be sure to test it when it is physically uncomfortably hot to the touch as bad voltage regulators show their ugliness then. Many have resorted to sticking the thing in the kitchen oven at 225 for an hour just before the test. Crazy, but it works.
Good luck!
Ed
Old Aug 29, 2019 | 02:04 PM
reverendxlt
I replaced the batteries... tested the alternator... Replaced the power supply in the FICM.
Now the FMP is actually showing 0.00 for main power and 5.5 for logic... Is there a ground that would affect this?
Old Aug 29, 2019 | 02:18 PM
TooManyToys.'s Avatar
TooManyToys.
More likely the connectors are not retained all the way in the FICM, or you pooched the board install.
Old Aug 29, 2019 | 02:20 PM
reverendxlt
They all clicked in like they are supposed to... guess I could have screwed up the power supply...
Old Aug 29, 2019 | 02:33 PM
bismic's Avatar
bismic
Still might call Ed at FICMRepair.com to see if he wants to mess with it (or maybe he will visit this thread again) ......................
Old Aug 29, 2019 | 03:36 PM
TooManyToys.
There are times its just better to ship the FICM to FICMRepair .....
Old Aug 29, 2019 | 03:41 PM
reverendxlt
All right, thanks guys. Will do.
d-day
Mar 31, 2014 09:43 AM
maevans
Feb 24, 2013 07:58 PM
yukonsly
Apr 28, 2007 08:22 PM
backhoeken
Electrical Systems/Wiring
Oct 8, 2005 05:56 PM
