Strange electrical gauge issue
Old Oct 6, 2005 | 08:40 PM
backhoeken's Avatar
backhoeken
I have a 1989 F250 7.3 with a strange electrica gauge issue. The gauge swings HARD to the left when power is turned off and only goes 1/4 of the way to the right when power is on.. The gague use to go 1/2 to the right.
With a volt meter I am consistently getting 12.74 at the power relay as well as the battery with the engine running.
Is this normal for older trucks or ????
Thanks
Ken
Old Oct 6, 2005 | 09:20 PM
Franklin2's Avatar
Franklin2
12.74v sounds like barely enough. Any starting problems lately?
Old Oct 6, 2005 | 09:41 PM
backhoeken's Avatar
backhoeken
No problems, starts right up
Old Oct 8, 2005 | 12:44 PM
backhoeken's Avatar
backhoeken
Question even more puzzeling
It started to work like normal. Measured the voltage at the battery 13.94v. At the battery the same.
Noticed that riht after starting it is in the lower half of the gauge and then snaps to the center of the gauge and stays there.
Any ideas ????
Thank
Ken
Old Oct 8, 2005 | 03:20 PM
Franklin2's Avatar
Franklin2
13.94v is more like it. The only suggestion I have is pull the cluster out, and take a pencil eraser and clean all the copper conenctions on the circuit board.
Old Oct 8, 2005 | 03:43 PM
backhoeken's Avatar
backhoeken
I tried to get it out but it only comes out 1.5 inch's
Old Oct 8, 2005 | 05:56 PM
Franklin2's Avatar
Franklin2
If your truck has a speedo cable, that could be holding you up. If you can, reach around or under to the back with your hand and see if you feel the cable. If you do, feel up next to the head unit, and there should be a clip there. Push the clip sideways and the cable should release.
KenS999
Mar 17, 2008 03:58 PM
fawey1
1983 - 2012 Ranger & B-Series
Nov 22, 2007 10:01 AM
tasdad
Aug 4, 2004 12:21 AM
fred m lewis
Computer Chips & Tuners
Mar 17, 2002 12:12 AM
