Another 4R100 Build
Got the trans out. Will post more pics this evening.
my question on all this is.... does this kit address the know issues with the 4r100,, sprague spring that jumps off,, center support bracket issue, I remember reading a article on john wood and he does a lot of machining on parts to make them bullet proof..
does this harden the 4R100 to handle say 80 more HP and the associated Torque that can result. ??
I made some good progress today. More to come soon.
Cleared the exhaust, frame and fender by jacking up the passenger rear tire higher than I would have liked to.
The pig is out!!!
Not too much on the magnet now, but I flushed the trans in June when I discovered a pan full of metal. Wish I would have taken a pic of that. It was gross.
On the bench.
Look at all the sludge.
More sludge.
The track that comes from the lower feed bolt in this photo is where I believe most of the sludge is coming from. Anyone know what that feed bolt feeds? Also, both these feed bolts were on the loose side. I easily snugged them up about 1/4 turn.
Sludge on the servo piston.
Transmissionbench.com homemade pump removal tool.
On the transmissionbench.com homemade stand.
The sludge in the pan looks normal to me. The sludge on the valve body gasket, (the gray sludge) I did not see in mine. It appears nonmagnetic or even water-based. Someone else may have more to say on it. The center support and a few other parts are the only Aluminum. So between those and then the valve bodies is the only places I could see that coming from.
New gasket for transfer to trans housing was $7.99 at Napa, if you need it.
Awesome looking truck
how long you think this going to take couple days or so.. I know we all gotta work and depending on weather , hot humid, its a PITA to work on $hi t outdoors in some places.I sure hope it does!!! I did not go with the transmissionbench.com kit, but instead picked all my own parts. I feel my build is pretty equivalent to a Stage 1. The only custom machined parts I'm putting in is the machined center support with an added snap ring and a billet input shaft. All the rest is pretty standard rebuild parts that address a most/all of the issues the 4R100 has.
how long you think this going to take couple days or so.. I know we all gotta work and depending on weather , hot humid, its a PITA to work on $hi t outdoors in some places.This might be the best 4R100 rebuild thread the FTE has and definitely deserves a spot in the Tech Folder.
Keep up the good work!
So far the biggest challenge for me was getting that damn roll pin for the gear selector rod out of the trans. Jimmy at the transmissionbench says this is the hardest part of the entire rebuild and I hope he is right.
I was looking over some of the parts last night and discovered some wear marks on the coast clutch drum. I've been scouring the internet for a replacement and have only had luck finding used parts that have these same looking wear marks. Maybe I'm overreacting. What do you all think?
Coast clutch drum wear marks.
The pig is out!!!
On the bench.
More sludge.
Sorry for showing all the photos again. But hey we like photos.
so i was watching video and he was removing the coast clutch in video 4 of 16 at the 15:00 mark and when he took it out I did NOT notice the marks you saw and took photo of on your or the use coast clutch. might be bad somehow.. ??
