oil filter bypass setup
Old Aug 11, 2019 | 12:17 PM
elishaman's Avatar
elishaman
Are any of you running this Asoil bypass oil filter setup, or do you know anything about it?
https://www.amsoil.com/shop/by-produ...?code=bmk33-ea
Old Aug 11, 2019 | 12:57 PM
94powerstroke's Avatar
94powerstroke
I’m thinking about running 1 now that im deleted im not sure whos i will run i like amsoils system because its a screw on filter. I have many customers who have them on their big rigs the filters on those look like a roll of toilet paper i think those systems are better.
Old Aug 11, 2019 | 01:50 PM
Overkill2's Avatar
Overkill2
First off, welcome you guys as your newer members here. I don't know anything about the Amsoil bypass but I do run a Filtrations Solutions FS2500 bypass.
I also posted pictures of it as well on another bypass thread here. The installation was very straight forward. I bought the spin on filter conversion but will use it after this next oil change is done. What's nice about the FS2500 is that it has a sample port fitting on it which makes it nice and easy to get a sample for a UOA.
Here's another thread I found by using the search tab on top.
Here's another by pass thread where I commented. Good luck with your choice. Any other questions or if you want some pics, please let me know.
All you have to do is search for what you are looking for:
https://www.ford-trucks.com/forums/s...rchid=28662573
Old Aug 11, 2019 | 02:13 PM
Just Strokin's Avatar
Just Strokin
I look at is as a company trying to sell you a product you, the average diesel pickup owner, might not need. Amsoil and others are in the business to make money.
Amsoil might be a great product and beneficial to the big rig tuckers since they go further than 7500 miles between oil changes.
If you were a hotshot driver, it might be beneficial to extending your oil changes if you are covering 5k miles or more a week.
Most of us do not cover 7500 miles in 6 months or even in 3 months. That is the oil life/change Ford recommends for the 6.7. Also, if Ford had felt the Motorcraft filter was not acceptable, they would have designed it differently or had a by-pass filtration setup in conjunction with the stock filter.
With one of the Fumto, EZ Oil Drain, etc valves, you can get a sample with relative ease also.
It is your money and your truck, if you think it will ease your mind, by all means order it and add it. Just remember in the 30??, 40?? years Ford has been producing pickup trucks with diesel engines, Ford has yet to add a bypass oil filtration system. I highly doubt Doddge/Ram or GM has a bypass filter stock.
Just my humble thoughts and 2 cents.
Old Aug 11, 2019 | 02:29 PM
Overkill2's Avatar
Overkill2
Hey Larry... I'm a pretty humble dude also, brother....
Old Aug 11, 2019 | 10:16 PM
94powerstroke
I only want the bypass to get the soot out of the engine in deleted now and i want to try and get as much of the soot cleaned out as i can. As for the engineers knowing best they don’t care. Ford gets your $80 000 for a truck they don't care if you get 5 years 10 years or 20 out it they just want your cash. These trucks were designed to fail put an injection pump on when it grenades it wipes out the fuel system a turbo with substandard bearings in it and an engine designed to eat its own barf and carbon every thing up. Ya the engineers know what they’re doing.
Old Aug 12, 2019 | 12:54 AM
bobcat67's Avatar
bobcat67
I agree with some of what you said, the emissions system is more of a Federally mandated thing than it is a ford thing. Turbo was kind of a joke, but know guys with 300-400k on their stock turbo's of that model too, the injection pump is what it is, GM used it, Ford uses it, and Cummins recently started using it
Old Aug 12, 2019 | 04:32 AM
Just Strokin
I think you have been reading too many horror stories in the forums. Forums tend to magnify problems that only affect a small percentage of vehicles.
so...
If you want the bypass, why ask? Why didn't you just buy it and install the bypass? Appears you had already made your mind up.
Old Aug 12, 2019 | 09:10 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
I used the Insane Diesel bypass oil filter system. I wasn't a big fan of installing something between the stock filtering system and the oil filter. The Insane Diesel and I believe the Filtrations Solutions bypass system come off the oil sending unit. My firm belief is that the single most important thing you can do to extend the life of your 80k investment is to take care of the oil. I use Lubrication Engineers oil which is red. I check my oil monthly. The 1st month after installing my bypass oil filter system and oil the oil still had a red tinge to it a month later. Prior to installing the bypass oil filter the oil was jet black after just a few days let alone a month.
Old Aug 12, 2019 | 10:48 AM
Overkill2's Avatar
Overkill2
Chuck is correct. The FS2500 hooks up to the oil pressure sensor port in the oil filter housing.
There is also this system as well. It was mentioned in one of the threads I posted.
Here's Chuck's Insane system.
Here's an article on bypass filtration.
Here's an article on the Amsoil system.
I included this article from Cummins Filtration's Fleetguard. I know this about the larger oil sumps from Class A vehicles but I thought this included pertinent info. Enjoy.
There's also guys still rocking out the original system, the Frantz bypass. Here. Here. Here. Just throwing this out there for FYI. Plus I learn as I go.
Old Aug 12, 2019 | 05:18 PM
KR2012F250's Avatar
KR2012F250
Running the Amsoil kit on my 2012 with good results. Plenty of life left in oil sample sent to Blackstone labs at 7500 miles.
Old Aug 13, 2019 | 12:48 PM
speakerfritz's Avatar
speakerfritz
I ran an amsoil by pass on my prior 6.4, mainly because of the common oil cooler clog problems .
but the 6.7 has a fairly easy oil cooler to service
Id put one on anyway but it would void my warranty
nmcqueen469
Mar 19, 2007 05:02 PM
Lushman
16
Mar 20, 2006 07:40 PM
MattB_1442
Oct 18, 2005 03:30 PM
okieakers
May 4, 2005 06:24 PM
wolffee
Jul 14, 2004 01:31 PM
