E4OD fluid leak extrem
Old Jul 12, 2020 | 06:30 PM
  #76
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Pin 30 is the MLPS + signal pin on the PCM .... it's tricky to do that without using a Break Out Box and I never like to poke holes in the wires.
IF you look at the manual you can see the full schematics at the end ... you would be better off using the Troubleshoot guide page 17 starting on 16 and verify those Numbers.
These tests are talked about again on page 39
Old Jul 12, 2020 | 06:44 PM
  #77
lonewolf_'s Avatar
lonewolf_
Scope Wizard
on that MLP sensor adjustment there just isn't much range of movement ..... like Mark says IF it only starts in N or P then you should be good to go.
Old Jul 12, 2020 | 07:42 PM
  #78
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Pocket E350
if the transmission switches to first gear, should the engine speed go up?
It will go up if you press the accelerator pedal. If you don't press it the engine speed will go down.
Old Jul 13, 2020 | 05:39 PM
  #79
Pocket E350's Avatar
Pocket E350
hi i would like to work according to the guide, but i never get all the brackeout boxes here in germany. this is really stupid.
Old Jul 13, 2020 | 06:13 PM
  #80
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you just have to kinda "Read Between the Lines" Basically what the Break out box is, is a pair of connectors that connect between the PCM and the PCM wire harness and it has a box with test points so that you can more easily probe the connections....
this is the Box I have... but it isn't needed but sure is handy.
It's not hard to make a breakout box IF you really feel the need...........
Here is a link to a DIY Break Out Box ...... http://www.merkurclub.net/kizerweb/s...s/breakout.htm
IF nothing else the chart on that website can be handy.
I Realize you are across the Pond so finding spare EEC-IV connectors in junque yards may be problematic... pretty plentiful here in the States
Old Jul 23, 2020 | 03:11 PM
  #81
Pocket E350
Hello
I have now installed a aux cooler.
the outside temperature was at 75F today. uphill the maximum temperature was 177F. Overland, the temp dropped back to 168F.
I hope it gets warm enough when the weather is cooler.
the "switch to neutral" error did not occur today.
Thank you very much for your great support.
Old Jul 23, 2020 | 05:50 PM
  #82
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you have problems in the colder weather you can always install a Thermal Bypass.
Old Sep 14, 2020 | 02:57 PM
  #83
Pocket E350
hello there,
hello we are back from vacation,
we drove about 3000 km.
no neutral shift dropouts from the transmission. didn't lose any oil and the temperature was always between 145-185F. it was a completely different ride with the cooler ATF.
Thank you for your first class help.
Marc
TulloFord
Feb 14, 2013 05:26 PM
Cods81bronco
Apr 7, 2012 09:04 AM
ATC Crazy
General Automotive Discussion
23
Feb 9, 2009 10:38 PM
PinkStroker
91
Nov 13, 2008 10:51 AM
