e4od to aode swap
Old Jul 14, 2019 | 12:39 PM
kregalmach1's Avatar
kregalmach1
yes i use my truck to pull dump trailers of fire wood logs should have a bigger truck sure but i got so much time and money in restoreing this one
Old Jul 14, 2019 | 01:49 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Ford also put that transmission (E4OD) in F-250s and F-350s so that shouldn’t be the weak link.
Old Jul 14, 2019 | 03:25 PM
EllieMae94's Avatar
EllieMae94
Have you considered a ZF5 swap?
Old Jul 14, 2019 | 08:18 PM
Mudsport96's Avatar
Mudsport96
How exactly did it explode? Are there parts in the pan or did it just quit working?
Old Jul 15, 2019 | 07:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A computer that runs an E4OD WILL NOT run an AODE. You must have a computer for an AODE.
Transmission shifts have to be timed very precisely and with the correct pressure. The timing and pressures for an E4OD will most likely destroy an AODE.
|WYG|SS
1978 - 1996 Big Bronco
Aug 2, 2010 12:52 PM
Mrboylston
Oct 7, 2008 08:32 PM
chevelle71
Jul 9, 2008 10:04 AM
currituckF150
Jul 22, 2007 10:28 AM
windyd
Apr 5, 2004 11:14 AM
