E4OD swap
Old Jul 1, 2019 | 06:50 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
E4OD swap
So my C6 build didn't go quite as well as hoped. Something came apart in first gear. I don't think it will be a difficult fix and I have another truck to put that in. I want OD and I've weighed my options between the gear vendor and swapping to an OD trans. I want the lockup convertor and as for cost, I think the gear vendor route is actually more expensive. I can get the E4OD with controller and TC for just under $3000. I need to shorten driveshaft and fab a few things, but I think long term this is the best route on wear and tear of my motor and driveline. So, not really trying to get my mind changed. Just wanting input from people that have done it. I've watched a few videos on youtube but I am curious about fitment with headers. Especially the shifter modifications and cooling lines. I've got Dakota digital gauges so I'm assuming there shouldnt be too much difficulty trying to connect the speed sensor with the bauman and the digital gauges. And any other tips to make this work. Thank You!
Old Jul 1, 2019 | 07:34 PM
Daveracity's Avatar
Daveracity
I’m in the middle of doing this right now. The transmission and tc are bolted in, but still need to fabricate the mounts, get the proper length drive shaft and install the controller. Hope to have it done in the next month
what transfer case are you using?
Old Jul 1, 2019 | 08:06 PM
TXTrailerdaddy
I'm putting it in a 2WD truck. Where did you get the transmission? I'm having a hard time finding a transmission. I've found a bunch of ones for a 7.3L diesel or small block in the junk yards. Most online suppliers want a VIN for a vehicle that it comes stock in. I was this close to buying a complete truck on craigslist just to get the core and vin so I can buy one.
Old Jul 1, 2019 | 08:54 PM
Daveracity's Avatar
Daveracity
I bought a complete 1992 truck and took the engine, transmission, transfer case and new tires and wheels. I got it for $2700 then sold of the balance of the truck.
Old Jul 1, 2019 | 10:14 PM
54Hydro's Avatar
54Hydro
Gearstar builds them to 600hp, 550ftlbs rating, but it will set you back $4500 plus $450 core.
Old Jul 2, 2019 | 08:22 AM
Mr.shift's Avatar
Mr.shift
For a 400M? You need a transmission that came out of a 460 truck. You already have some type of EFI to run the Bauman controller?
Old Jul 2, 2019 | 02:01 PM
TXTrailerdaddy
Yeah, I know I have to find one for a 460 but it is really hard to find one. There are plenty for 302s and 7.3L diesels just not for 460s. I'm running a carb at the moment, so I will need a throttle position sensor for the Baumann. Eventually I will switch to EFI but not yet.
Old Jul 2, 2019 | 03:08 PM
JP3's Avatar
JP3
Did you search car-part.com? Found a few on there.
In the past I've seen some on craigslist from guys parting out motor homes.
Old Jul 2, 2019 | 03:14 PM
flowney's Avatar
flowney
It is possible to get a 4 speed automatic that does NOT require an electronic controller if you are willing to consider a GM tranny. See TCI Automotive. Not sure if 4th is 1:1 or OD - have queried TCI to find out. The BBF model should work but you really might prefer a 460. The 429/460 was manufactured between 1968 and 1997 for all sorts of cars, trucks, RVs, boats and even static industrial use. They are out there in good quantity. Of course Ford will sell you a brand new race-oriented block if you have the dough on hand.
Old Jul 2, 2019 | 09:15 PM
BLK79's Avatar
BLK79
TXTrailerdaddy if you want to drive to NW OKC I'll give you one. It is in a 92 F250 2wd. Bought it for (and pulled) the 460. Seller said trans had blown fluid from front seal. I trailered it home. Put fluid in it and it drove/shifted fine. Didn't get it hot towing or anything, was really just trying engine out. Put the 460 in a Bronco, sold the flatbed, used the rear leafs on my 92 4wd.
Old Jul 3, 2019 | 02:13 AM
TXTrailerdaddy
Thanks! well, seeing as I really just need a core, I can pick up an E4OD with one of the other bellhousings. Monster told me they will let me send them any E4OD core..... However, I may need a vin to get these guys to sell me a trans. Which is ridiculous.
Old Jul 3, 2019 | 07:30 AM
BLK79's Avatar
BLK79
If you need the VIN for same truck let me know. Only reason I can think of they want the VIN - there were some changes to how the trans solenoid pack is controlled by the engine computer. I think the change was around 92-93 but not sure on that. If I remember right the correct soleniod pack can be swapped fairly easilly.
Old Jul 3, 2019 | 07:37 AM
ford390gashog's Avatar
ford390gashog
E40D cores are so cheap it's not funny, I pick cores up for 50.00 a piece at the local u pull. That's straight from the core bin no labor on my part. You should be able to find one, the 90's work trucks are prevalent still.
Old Jul 3, 2019 | 08:11 AM
JP3's Avatar
JP3
This ^^^^^ and later models do not have a transmission mounted speed sensor. They have a hole, but have no gear or tone wheel on the the output shaft.
Old Jul 3, 2019 | 05:33 PM
EQCMCAT's Avatar
EQCMCAT
Thought I read some post awhile back with a few guys opting to swap their C6 for the Ford AOD automotic over-drive transmssion that's non-electronic and if I remember correctly that pulled them from ~ 1988-89 F-350s.
