E4OD swap
So quick question for us uneducated with the E4OD... what's the controller for?
Its because the E4OD is an electronic controlled transmission. The controller sets shift points and how the transmission reacts in certain conditions. It also gives you info related to the trans like gear it’s in temp of trans or when the TC locks.
Or, will the C6 yoke work? I thought I had read something that it wouldn't but as I do research, it cross references that both are 31 splines.
Big gaping hole where the tranny used to be. Both braces out and passenger side header out.
Now for some size comparisons. The E4OD is a monster and the Derale 8qt pan makes it even bigger.
I cut off the ear on the front because Hotrod Magazine said to. It's really iffy on if you need to, I'll show you a pic with it in, but it doesn't hurt anything to take it off.
Here it is in place. The reasoning is that it hits the floor pan. It doesn't look like it would, but it is in the way of the header.
Here's the trans in place. So there are 2 different options I came across for the rear brace. The magazine says use the stock brace moved back notched 1/2 lower. I saw a posting of using 2x2x1/4 and welding a plate to the bottom then setting the 2x2 on top of the bottom rail of the frame, which I admit seems like a much more stable option. if a nut came loose. I used 2x2x1/4 and drilled the top for the E4OD transmission mount (some use the C6 mount).
The front of the transmission is a bit higher than the back. It helps a little with the driveline angle and since I have the deeper pan, I'm not too worried. Plus, there isn't much space between the top of the tranny and the tunnel. I need a little there and this works for me. So I put the front driveshaft on with about 1 inch or so from being bottomed out and measured from where the carrier bearing mounts to the carrier bearing.
For the coolant lines I am using AN6 and 3/8 hose.
Only problem is really the front line. It is too close to the floorpan, I need to get a 90 Degree fitting for it.
The front brace really doesn't need to be modified on the 2wd. If you have 4 wd, the brace is different. Here's the brace in place. I looked at the possibility of putting the 2x2 in and it does fit. I think 1 1/2 would be better. I'm going to leave mine alone as I don't expect to have to pull this trans out, and when I do I think I will be putting a coyote drivetrain next. Second pic has a piece of 2x2 so you can see how it fits.
Shifter is my next problem. I found this bracket on a 96 diesel with a cable and thought it might be a way to solve the shifter issue. Still working through that.
I really don't like the heim joint option and I think a shift cable is the way to go. I'm looking at a few Lokar options. Not cheap but seems very plausible. I'll update as I make more progress.
All in all I worked about 4 hours on it today. Feel free to ask any questions.
Don't remember anyone asking this, but did you happen to take some 'before' data on the C6 @ highway speeds (rpms, tire size, etc)? And do you plan on posting up some 'after' data?
