TS Performance Chip
Old Jun 27, 2019 | 05:06 PM
TBigLug's Avatar
TBigLug
TS Performance Chip
Does anyone know where to get the TS chip but with differant tuning? Everywhere I look it only lists the 6 settings stock, high idle, 50, 75, 100 and 140. I want to ditch the 140 for the valet setting and change the order to high idle, stock, 50, 75, 100, valet. Anybody know where I can get that setup? Thanks.
Old Jun 27, 2019 | 06:04 PM
Wes444's Avatar
Wes444
Probably every one of the forum's supporting vendor tuners are willing to take your money hook you up
Old Jun 27, 2019 | 06:49 PM
greg_8507's Avatar
greg_8507
Any tuner should give you what ever tune you want. I'm also pretty sure the number of tunes you have are limited more by the switch than the chip. I can't speak to other tuners as I have only had DP-Tuner, but I chose precisely which tunes I wanted. My switch is also a 16 position switch so I could have up 16 different tunes. I've seen the exact same switch sold by other tuners so your options should be pretty open.
Old Jun 27, 2019 | 07:47 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Don't buy the TS chip then send it to a tuner, just buy one from a tuner with tunes. Any tuner can hook you up. DP Tuner, PHP, etc. I've used both, no complaints.
Old Jun 27, 2019 | 08:29 PM
00t444e's Avatar
00t444e
The Hydra chip is a much better choice, you can put whatever tunes you want on it, and any tuner can email you there tunes so you never have to send it in.
chrisbrady498
Jul 2, 2014 02:54 PM
dealwithit
Computer Chips & Tuners
Jun 7, 2013 02:25 PM
reality_check
Feb 1, 2013 12:04 AM
blhfla
15
Dec 16, 2005 05:13 PM
farmb0y
Aug 1, 2004 12:00 PM
