Best Value E4OD
Old Jun 28, 2019 | 10:22 AM
CamoF-250's Avatar
CamoF-250
Originally Posted by Deadsquiggles
93 with a 5.0. Not finding any codes.
To be clear you have 111 for both KOEO and KOER? I had all kinds of issues, including no forward movement when my last PCM failed, no results for tests, no codes at all.
Old Jun 28, 2019 | 01:16 PM
rla2005's Avatar
rla2005
There is not going to be any codes for the OP's issue. This is another example of why posting the same issue in multiple forums results in multiple people asking the same questions, but the answers are in different places.
Mark K. hit the root cause and resolution on the head in the OP's other thread: https://www.ford-trucks.com/forums/1...l#post18724058
spoiler alert...
Let's make sure I understand what's going on.
The trans works in reverse and when the shift handle is in 1 or 2. If you put it in D it won't go. Is that correct?
If that is correct pull the transmission and rebuild or replace it. The overdrive one way clutch has failed. Don't listen to those that tell you it could be the transfer case or the solenoids. It can't possibly be either of those.
Old Jun 28, 2019 | 01:28 PM
CamoF-250's Avatar
CamoF-250
Sorry I was only suggesting trouble shooting the solonoids to save him some money. If the OD clutch fails, could that be remedied by turning of the OD with the switch?
Old Jun 28, 2019 | 03:49 PM
Briansshop's Avatar
Briansshop
No, but if you mean OD One Way Clutch, check the sentence at the bottom.
Old Jun 28, 2019 | 07:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why? The solenoids couldn't possibly cause this to happen. So why waste time on them?
Yes, that will work. I don't know if it will work long term, the coast clutch wasn't designed to handle that load without the one way clutch.
Mustangfreak
Feb 17, 2009 08:50 PM
javi2001
Mar 5, 2004 01:01 PM
allison1
Mar 1, 2004 04:19 PM
78ford100
Jan 21, 2003 12:00 AM
ScottR
Jun 27, 2001 12:34 AM
