Rebuilding my E4OD...
Old Mar 3, 2004 | 12:54 PM
javi2001's Avatar
javi2001
Hi all, recently I got from a yard an E4OD wich was rebuild by Ford, it has one sticker at side "Quality Renewal by Ford", after disasembly Surprise... all components are almost new ! ! ! Even clucht disk still having part numbers full visible...
Well tranny has a dateplate at side and I want some help to understand the info:
DATE: 200-6
FOTZ-7000-GRM <<< could be FQTZ
R-380178
I want know how decode date, because I'll need this info to know if need some upgrade.
More over; I found a small filter UNDER reinforcement plate (Not the filter locate OVER plate) this doesn't appear in my Ford Shop manual 1991 so I guess it could be some upgrade for trany but I don't remember where it was located Any ideas???
I'm planning just clean parts and re-assembly and also change output shaft to convert it to 4X4. Someone told me the oil pan and maim oil filter are also differents to 4X2 model, is this true??
Any help will be appreciated.
Regards;
Old Mar 4, 2004 | 03:50 PM
javi2001's Avatar
javi2001
No ideas yet???
Old Mar 4, 2004 | 04:13 PM
donnor's Avatar
donnor
E4OD issues
I too have a 1995 2WD E4OD that I would like to convert to 4WD, using components from a 1994 Bronco E4OD. A tranny shop tech has led me to believe that this would not be an easy thing to do. True? Or is he just trying to get a rebuild job out of the deal?
dn.
Old Mar 5, 2004 | 01:01 PM
javi2001's Avatar
javi2001
As far as I know, it's necessary disassembly thw whole tranny, because he needs replace output shaft.
My parts book say just a few parts are different like output shatf, output cover, 2 bolts on output cover, main oil filter, oil pan and one more part I don't remember name...
Hope someone can point me to WEB page or pictures to reasembly my tranny
