Time for New Wheels: -44 Offset?
Old Apr 29, 2019 | 01:24 PM
G8REx's Avatar
G8REx
Question Time for New Wheels: -44 Offset?
Hello All,
I'm the proud third owner of a fully restored 6.0 Excursion, and the current wheels I have (18x9.75 Series 1069 Pro Comps) are trashed and in need of replacing...terribly pitted.
I'm considering a set of AXE Compression wheels (https://realtruck.com/p/axe-offroad-...xcursion/2004/), but know very little about offset.
I'm hoping for a "clean" look that doesn't push the wheels really far outside the wheel wells, and didn't know if anyone could weigh in whether -44 offset will play nicely with the Ex.
Thanks in advance for your input.
Old Apr 29, 2019 | 01:47 PM
pirate4x4_camo's Avatar
pirate4x4_camo
No, a -44 is not going to play nice with your Ex.
Old Apr 29, 2019 | 10:11 PM
wpnaes's Avatar
wpnaes
No bueno
Old Apr 30, 2019 | 08:22 PM
strogg's Avatar
strogg
Ditto. With these wheels, it's not the offset that you need to worry about, but the width, as you can see in the picture above. They look like that because they're 12" wide. You're best off with a 9" wide wheel to keep the tire profile more normal looking. Now if you can find a 9" wide wheel with a negative offset, then that would be more ideal to avoid rubbing.
Old May 1, 2019 | 10:52 AM
oharal's Avatar
oharal
But if you don't have 12" wide wheels how will the people know your dad is also your uncle?
Old May 1, 2019 | 07:53 PM
G8REx's Avatar
G8REx
Thanks for weighing in fellas...it’s so hard to find wheels that look clean that don’t have doofy offset appropriate for a 16 year old with too much money. I miss the old Weld Racing wheels from the late 90’s / early 2000’s.
Old May 1, 2019 | 08:22 PM
G8REx's Avatar
G8REx
Perhaps these could work?
https://www.customwheeloffset.com/bu...sic-ss-20x9-0?
They’re available in 20x9 with 0 or -25mm offset. Which do you think would give a good look without hanging super far outside wheel wells with lowest chance of rubbing?
Old May 2, 2019 | 09:56 AM
Squirrel13's Avatar
Squirrel13
https://www.discounttiredirect.com/f...nalPlusSize/18
Old May 2, 2019 | 09:58 AM
Squirrel13's Avatar
Squirrel13
This is one of the models I am looking at black-rhino-warlord
RenoHuskerDu
15
May 27, 2025 09:18 AM
Live4yotas
Oct 30, 2013 05:29 PM
Kasick
Dec 6, 2006 03:46 AM
rfairwea
Dec 26, 2005 01:57 AM
STJones
2004 - 2008 F150
Sep 26, 2004 01:08 PM
