Wheel offset?
Old Sep 16, 2004 | 06:54 AM
STJones's Avatar
STJones
Wheel offset?
I really like the American Eagle 178 wheels (like Blkbuty). I am being told by a salesman that the wheels won't stick out past the fender. This seems contrary to what I am reading on here. The wheel offset is +2 mm and I know that the factory wheels are +44 mm. I have to admit that I am ignorant to wheel measurments. I guess the point is I really like the look of those wheels but I don't want them took stick past the wheels well a lot. I have the XLT. Thanks in advance.
Old Sep 16, 2004 | 01:31 PM
MALIBUBASS's Avatar
MALIBUBASS
If you don't want your wheels to stick out go with 5- 5 1/2 backspacing. Stock is 5 1/2 on a 8" wide wheel.
Old Sep 16, 2004 | 03:08 PM
roboots21's Avatar
roboots21
If that is the case then you should be all set, cause the backspacing on the 178 series is 5". I am lookin into those rims also, but am just thinking about putting some 285 BFG's on the stock 18's, or see if BFG comes out with a nice 33x12.5-18 instead of 11.5
Old Sep 16, 2004 | 04:52 PM
STJones's Avatar
STJones
So the backspace is what matters - not the offset so much?
Old Sep 16, 2004 | 05:35 PM
04fx4scab's Avatar
04fx4scab
i believe the stock wheels are 7.5" wide with a +44mm offset.
Old Sep 16, 2004 | 06:04 PM
Paul f150's Avatar
Paul f150
Wheels for our trucks are similar to front wheel drive type wheels. Our hub and disc brakes stick way out so the stock wheels are very high off-set +44. The stock wheels almost stick out past the front fenders on the XLT. I bought 20"x8.5" with +40 off-set and they stick out about 1/2" past the fender in front. It seems like there is more new styles of wheels available all the time. Also, Ford truck wheels are hub centric and not lug centric and sensitive to out of balance conditions.
Old Sep 21, 2004 | 08:01 PM
hoff's Avatar
hoff
eagle series 101 17x9 with 5 inch backspace 35x12.50r17 tires
Old Sep 25, 2004 | 09:49 PM
blkFRDf1504x4lar2004's Avatar
What I am hearing about lifts you have to go with 5 inch or less backspacing on a 8inch wide wheel for the new F150's. I purchased the CST 8inch lift the other day, now I am in search for rims and tires. Any suggestions. I am wondering if they make a 20 x 8 with 5 inch backspace rim. Also a 37 x 12.5 tire to fit...
Old Sep 26, 2004 | 10:36 AM
JohnAndHisDog's Avatar
JohnAndHisDog
STJ, here's some FYI stuff for you:
http://www.usacomp.com/Offset.htm
http://toy4two.home.mindspring.com/offset.html
Old Sep 26, 2004 | 11:02 AM
STJ, here is a better understanding: Must use Internet Explorer.
http://www.bigwheels.net/
click offset
Old Sep 26, 2004 | 11:36 AM
JohnAndHisDog
Something must be off on this site today. Links are showing up strange.
Old Sep 26, 2004 | 12:59 PM
links are messed up: www.bigwheels.net
http://
www.bigwheels.net/
Old Sep 26, 2004 | 01:08 PM
2004 Ford F150
http://www.mhtwheels.com/gallery_veh...?brand=2&id=29
2004 Ford F150
Brand : Concept Neeper
Principle
Aug 14, 2013 11:45 PM
akarteam
Aug 11, 2013 09:53 PM
redbull660
Jan 9, 2012 09:30 PM
