Speedometer cable lube
Old Apr 23, 2019 | 02:37 PM
casper1999's Avatar
casper1999
Just got a new speedometer cable/housing from Dennis Carpenter and I have a couple questions. The new cable housing is 7 inches longer than the old one but is listed for my application (51 F3). Also does the new core need to be removed from the new housing and lubed? It seems to have a very thin coating of oil but I don't know if that's a pre-lube or residue from manufacturing.
Old Apr 23, 2019 | 05:57 PM
pbsdaddy's Avatar
pbsdaddy
Generally speaking, speedo cables are not "lubed", other than what you have already found. I have heard of people spraying powdered graphite into the cable housing, but I really don't think it is of any benefit. On the other hand, the cable drying out and rattling is the most common failure. But that can take several decades and kinda removes it from the areas of concern.
Seven inches is a lot of extra cable to have to deal with. I think you may want to send it back and re-order. This time, telling them the length of cable you need.
Old Apr 23, 2019 | 08:16 PM
raytasch's Avatar
raytasch
Believe Nothing
Graphite has always been the speedometer cable lubrication of choice AFAIK.
Old Apr 23, 2019 | 08:24 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Yeas ago I worked at a Cadillac dealership. When we had cars come in with noisy or bouncy speedo needles we'd pull the cable out of the housing and clean it up with carb or brake clean. Then we'd dip the tranny end of the cable into a tube of Lubriplate assembly lube and then push it back inside the cable housing and work it in and out while re-inserting it. It worked like a charm.
Bobby
Old Apr 24, 2019 | 12:07 AM
casper1999's Avatar
casper1999
Ok thanks guys, I'll do a test fit to see if the extra long cable housing will work and if so I'll pull the core back out and lube it like Bobby suggests. Thanks again.
Old Apr 24, 2019 | 03:50 AM
TitusDH's Avatar
TitusDH
….and here's one more vote for powdered graphite. Any liquid will solidify over the decades and gum the cable up. Mine sheared in half and the speedo was frozen too, as a result of some one putting oil into the cable probably sometime in the 60's......
IIRC, the right cable length would be 71 in.
Wil from Hamburg
Old Apr 25, 2019 | 03:21 PM
casper1999's Avatar
casper1999
UPDATE: The speedometer works!!! The extra length turned out to be a non-issue. I used grafite to lube the cable,put it all back together and success! It reads 5mph off, 30 showing/25 actual, but the needle operates smoothly. Thanks to all for your help.
Old Apr 25, 2019 | 05:07 PM
bobbytnm's Avatar
bobbytnm
Woohoo!
I'm glad it worked out for you
Bobby
49f3dls
May 25, 2016 07:37 AM
backdraft341
Oct 13, 2010 11:44 AM
plilikoi
Bronco II
Feb 28, 2006 07:44 PM
79beater
Jan 17, 2005 09:05 PM
dogdays
Jan 14, 2004 08:40 AM
