Sponsored by: Real Truck
Shift Solenoids
Old Apr 16, 2019 | 07:41 PM
BrianKass's Avatar
BrianKass
Shift Solenoids
Hello, new to forum. Got me a transmission issue. I have a 2011 built 09-2010
I have a shift flare from 3rd gear to 4th and down from 3rd to 2nd. Only when the transmission is cold (mornings only) doesn't do it the rest of the day, once the transmission warms up.
From what I have read I need to replace the (3) high solenoids. I think I am capable of doing this. Couple questions.
I won't know which band number they are until I pull them? Is that correct?
Also my main question is do I need to re-program the PCM and TCM after I replace them?
Any good recommendations on where to get the solenoids?
Thanks in advance
Brian
Old Apr 17, 2019 | 09:10 AM
Fefanatic's Avatar
Fefanatic
There is no reprogramming to be done with solenoid replacement. What does the fluid look like?
Old Apr 17, 2019 | 09:32 AM
DeeDubz's Avatar
DeeDubz
Had the same issue with my truck a few yrs ago. After taking it to the dealer twice they finally figured the problem out. The dealer replaced solenoids and reflashed the transmission.
Old Apr 17, 2019 | 11:10 AM
BrianKass's Avatar
BrianKass
Fluid looks ok, kinda a dark red, correct level, but is overdue for service.
Old Apr 17, 2019 | 11:16 AM
BrianKass's Avatar
BrianKass
Hey DeeDubz,
Can you give me an idea on what they charged you? My local Ford dealership here wants $ 1,200 to service the Transmission, replace the 3 high solenoids and I assume reflash the transmission but not sure on that. Seemed high to me.
Thanks
Brian
Old Apr 17, 2019 | 11:55 AM
DeeDubz's Avatar
DeeDubz
hmmmmm sadly I can't give you a number. My issue was covered under warranty.
Old Apr 17, 2019 | 12:12 PM
Just Strokin's Avatar
Just Strokin
Here are a few links....the first one I would put a lot of faith in what Ford Diesel Doc says without any questions.
https://www.thedieselstop.com/forums...enoids-461762/
https://www.ford-trucks.com/forums/1...roblems-2.html
https://www.ford-trucks.com/forums/1...t-problem.html
another link
https://atracom.blob.core.windows.ne.../2015_3_12.pdf
might want to search the 6.7 forum
6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Miguel P
Aftermarket Products
Oct 19, 2018 05:51 AM
Mike1016
Jul 22, 2018 03:18 PM
havoxx33
1983 - 2012 Ranger & B-Series
May 7, 2012 01:48 PM
FTrookie
2009 - 2014 F150
16
Mar 7, 2010 06:57 PM
rverg
Jul 7, 2004 08:54 AM
