any shift solenoid recommend for my 99 4Runner? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Reload this Page >
Old 10-17-2018, 04:05 AM
Miguel P
Miguel P is offline
Miguel P is starting off with a positive reputation.
Hi, Guys my mun's 99 4Runner has met some problem on shifting, the transmission gets stuck in neutral. I find some shift solenoids replacement on amazon, is that okay for me?
A340 solenoid A340 solenoid
Old 10-18-2018, 11:38 PM
cosmofennema's Avatar
cosmofennema
cosmofennema is offline
cosmofennema is starting off with a positive reputation.
Generally when an auto trans does not move in a forward range, it's low on fluid or the clutches are slipping badly.
Occasionally, though uncommon, the front pump is bad. There are a couple others, but shift solenoids do not make the cut.
Put simply: go ahead, buy the solenoids; they won't fix the problem, unless the problem is a wallet that is too heavy.
Check the fluid. If it's ok, rebuild the transmission.
Old 10-19-2018, 06:15 AM
Miguel P
Miguel P is offline
I think you're right, maybe I should check the fluid instead of change a solenoid.
Old 10-19-2018, 06:51 AM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.00t444e is gaining momentum as a positive member of FTE.
The A340 is basically the same transmission as the AW4 that came in the Jeep Cherokee XJs so I do have some experience with them. They have 3 shift solenoids two of them control what gear it is in and the other is for converter lockup. When the two shift solenoids aren't powered or are bad it defaults to 4th gear which makes it not want to move in drive, however you can still manually shift it into 1st gear so you should try that first.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
