Delay in tranny shift
Old Jul 6, 2004 | 08:54 PM
rverg's Avatar
rverg
Hello, New to this. Just bought a used 2002 f250 PSD it has 95000 miles on it.
I have researhed the forum postings on transmissions, many good listings, but have not seen this type of issue posted.
When the truck is cold (in texas not that cold) but has sat for a period of time (in excess of 4 to 6 hours) and I go to shift the truck into gear, it takes about 60 to 90 seconds before the transmission will engage into any gear.
Once the truck has warmed up the truck appears to shift into gear normally.
thanks/rverg
Old Jul 6, 2004 | 10:47 PM
FoMoCo136's Avatar
FoMoCo136
Have you done all of the simple stuff like check the fluid level, color, and smell?
Old Jul 7, 2004 | 06:52 AM
rverg's Avatar
rverg
yes, fluid did not smell burned, even had the transmission fluid changed. Its an automatic.
Old Jul 7, 2004 | 08:54 AM
gunfrk's Avatar
gunfrk
I had a T-bird that wasn't serviced often enough and was exhibiting the same symptoms you have. I had it serviced and knowing the risks of the service killing or fixing the tranny I lucked up. What I found on this one was the fluid was worn out. It wasn't burned or smelly, just worn.
83scrambler
Oct 31, 2013 04:47 PM
FTrookie
2009 - 2014 F150
16
Mar 7, 2010 06:57 PM
eigenvector
1983 - 2012 Ranger & B-Series
Jan 2, 2009 08:49 AM
Oscar Meier
Aug 22, 2008 01:37 PM
