Boost Behavior
Old Apr 17, 2019 | 10:11 PM
Pyroneer's Avatar
Pyroneer
I was hoping the woosh was natural, but I haven't checked yet. Is that boost drop normal when letting off the gas?(Not shifting)
Old Apr 18, 2019 | 08:56 AM
knottyrope's Avatar
knottyrope
no fuel = no boost
remove foot off pedal and boost will drop
if it drops too fast and you have a woosh...........you have a boost leak
use a leaf blower on exhaust and some soapy water
buy a fernco coupling at home depot or lowes with a few bushings and adapters to a compressor to pressure up turbo inlet and spray some soapy water around
Old Apr 18, 2019 | 01:22 PM
Pyroneer's Avatar
Pyroneer
Does the drop in my video look too fast?
Old Apr 19, 2019 | 07:43 AM
knottyrope's Avatar
knottyrope
hard to tell in the video since I am not pressing the pedal and was only a short run
You have a woosh
You think its acting up
Sounds like a boost leak
Only way to really tell is to test to put it to rest
Old Apr 21, 2019 | 02:13 PM
Pyroneer's Avatar
Pyroneer
Mad truth. For the inlet, what do you use on the coupling to cap it off?
Old Apr 22, 2019 | 03:53 PM
knottyrope's Avatar
knottyrope
I use a fernco rubber coupling and add PVC bushings to 1/4 NPT and add in a compressor quick coupling
Rod Jr.
Jan 28, 2019 11:16 AM
derek0525
13
Jan 19, 2016 03:57 PM
KIDkiser
May 12, 2014 06:38 PM
jimwilsonmasonry
Jan 2, 2009 12:28 AM
cdiddy
29
Feb 7, 2008 12:26 PM
