How much Boost should I be getting
I just got my new up pipes put on as well as a 38R and pulling a hill hard my truck will hit about 22 psi then drop off slowly I have an electronic boost fooler wich has been on the truck since new pretty much but I don't get a CEL at all is this what I should be getting and I was on the 80hp tune? I ordered new boots and plenum inserts they just haven't got here yet. I know I had a leak before on my old up pipes because they rattled every now and then and I could see exhaust coming out of them when it was cold out but I could hit about the same 22 boost with my old setup. So pretty much nothing changed boost wise except it gets up to boost faster now. I would say it's defueling but I was always told the CEL would come on if that was the case.
Since upping the injectors and going to a 38R, I limit my boost to 35 PSI - no point in pushing my luck with 300K-mile valve springs.
Defueling occurs at a specific RPM on a stock program, not at a specific boost - and it will not throw a SES light when it does occur.
80HP tune I still haven't tightened down the waste gate just disconnected the red line I have the Banks Big boost on my stock turbo that I was game have them put on the 38R but the shop said the one that came with the 38R was about the same quality. I will try tightening down the waste gate rod I also made a Boost leak detector just waiting for the weekend
I saw it... boost leak. I am very afraid your gauge did the signature "twitch" of an intake plenum leak. I'll explain that better:
When a boot leaks, it's reasonably constant. When the plenum seal is compromised, it makes a raspberry (or fart) when the upper boost numbers are reached. I hope I'm wrong, but do the boost leak detector thing and really focus around the intake plenum seals. Stock sticks, stock turbo, 80 HP tune (before my big mods):
Aaaand here's when I first noticed a small leak in the plenum:
