Boost ??
Old Feb 5, 2008 | 05:18 PM
cdiddy's Avatar
cdiddy
Boost ??
Here are some things that I have noticed with my new boost gauge installed.
Just driving around town I will have no boost. Doing 80mph @ around 2000rpm I have about 5 to 8 psi. On WOT its around 20psi. Are these number right? If im not on the gas I have no boost.
Old Feb 5, 2008 | 05:23 PM
nlemerise's Avatar
nlemerise
Sounds about right to me...
Old Feb 5, 2008 | 05:24 PM
Badluck's Avatar
Badluck
yea thats right
Old Feb 5, 2008 | 06:10 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
With your programer that is about right. I have the DP-TUNER and I can get 30# if I let it. I try to keep it around 25# when I get on it.
Old Feb 5, 2008 | 06:43 PM
HKusp's Avatar
HKusp
I think my overboost annihilator is set wrong. I am getting right around 22.5 and then the truck throws a check engine light at me.
Old Feb 5, 2008 | 06:50 PM
miller_feed
Jason, I have yet to throw a code with up to 30# boost. My lite has not come on yet. I don't do the high boost often, but when I do I get lots of turbo surge.
Wish I had an answer for you but I don't.
Old Feb 5, 2008 | 07:02 PM
MikeSDK's Avatar
MikeSDK
Thats about exactly what I see.
Old Feb 5, 2008 | 07:53 PM
empiretc's Avatar
empiretc
those numbers sounds right. you need to stomp on it to build boost (climb a hill), but I never really want to take it over 20. cruising on the highway @65 i see 3-5.
Old Feb 5, 2008 | 08:21 PM
budfans's Avatar
budfans
I just started the install with mine and boost is the first one up and running , i have the same numbers too . next will be trans then pyro what number will i see when there wired up?? i,m all stock but the filter......... for now!!
Old Feb 5, 2008 | 08:28 PM
wd13's Avatar
wd13
Really? I cant get over 26#'s even on the 140 setting
Old Feb 5, 2008 | 08:46 PM
miller_feed
Yes, I can get it up to that. I don't have any leaks with my boots. I have to let off on the go pedal to keep it at 25# boost, and she is still pulling. I don't know if it is because I have a very heavy truck on not. But I can build that kind of boost.
Old Feb 5, 2008 | 09:02 PM
cdiddy's Avatar
cdiddy
So how would you get more boost? More fuel and injectors?
Old Feb 5, 2008 | 09:05 PM
ford&excavators's Avatar
ford&excavators
My truck with an SCT programer gets up to about 24-26 psi. Its about 3-5 on the highway at 70-75. I don't have the overboost annihiator. I think I'm going to get the wicked wheel next. Will that change my max psi?
Old Feb 5, 2008 | 09:07 PM
empiretc's Avatar
empiretc
they will vary some depending on outside temps. the warmest I have seen my tranny at is ~165 just empty truck. pyro will vary, but it won't be too big of a concern with a stock, empty truck. you'll notice it will climb faster once you get a chip. just remember to keep the pyro under 1200. just watch out, it is easy to let gauges get out of hand. you'll want to start keeping an eye on everything, lol.
Old Feb 5, 2008 | 10:12 PM
nhill2090's Avatar
nhill2090
im convinced its because of the early 99 turbo, i see 26 at most also, unless i unplug the red wastegate line then i can see 29-30
