2015 P0170 CE light
Old Mar 5, 2019 | 03:56 PM
MikeRizz's Avatar
MikeRizz
2015 P0170 CE light
About two weeks ago my truck triggerd a CE light. I pulled the code and it is P0170. Fuel trim malfunction. The truck seems to be running fine. I cleared the code and it came back yesterday. I found a couple of threads here but did not seem to be a conclusive answer. Seems a ECU re-flash may be in order? Here is the thread:
https://www.ford-trucks.com/forums/1...ank-1-a-4.html
Anyone have the re-flash done?
I did find there is a TSB issued from Ford:
Bulletin Number: TSB 16-0134
Bulletin Date: 10-05-2016
Component: 060000 engine (pws)
Summary:
Some 2015-2016 f-super duty vehicles equipped with a 6.7l diesel engine may exhibit an illuminated mil with dtc p0170 (fuel trim bank 1) stored in the powertrain control module (pcm) memory. reprogram the pcm to the latest calibration.
Old Mar 5, 2019 | 05:20 PM
dirthawg's Avatar
dirthawg
Took my truck to the dealer for the same code. They flashed it to the latest version at the time on January 2018 and have not had a CEL since.
Old Mar 5, 2019 | 07:53 PM
MikeRizz's Avatar
MikeRizz
Perfect. Thank you! Looks like a dealer appointment is in order.
Old Mar 6, 2019 | 05:56 AM
drillmaster's Avatar
drillmaster
Summary:
Had the same issue back in 2017. Had the dealer perform the PCM flash, per the TSB, and haven't had any issues since.
Old Mar 6, 2019 | 07:30 PM
MikeRizz's Avatar
MikeRizz
Thank you!
bkuuz1
6.7L Power Stroke Diesel
72
Feb 21, 2023 10:37 PM
Chinookman
6.2L V8
May 24, 2019 08:19 AM
tracyclifton
Jan 31, 2016 05:15 PM
ramsay
Jan 16, 2016 10:01 PM
