Door Chime Continues To Ring
Old Dec 31, 2018 | 02:39 PM
Texas Mad Man's Avatar
Texas Mad Man
2000 E150
The chime that sounds when the door is open with the keys in the ignition and sounds when the lights are left on is chiming
with lights off, door closed, and driving down the road. Should I suspect the door light switch or something else. Anyone ever had this problem
It's driving me nuts. Thanks and Happy new Year.
Old Dec 31, 2018 | 02:55 PM
NICKSAN's Avatar
NICKSAN
It might be the ignition switch. When I changed out mine the chime would come on when I moved the steering column up and down. I pulled out the switch and put it back in and it stopped doing it.
If I remember correctly there was a little connector and wire that operated the chime on the ignition switch and had to be placed just right.
Old Dec 31, 2018 | 03:21 PM
Texas Mad Man
Nick: Thanks for your reply. I will check into that.
Old Jan 1, 2019 | 04:47 AM
JWA's Avatar
JWA
In a column that's working correctly there is a contact that when installed does sound the alert keys are still in the ignition cylinder with engine off and driver's door opened. That contact looks like this:
Installed:
FWIW that feature bugs the crap out of me so I've removed the contact, wrapped it in electrical tape and tucked it away inside the upper shroud---of course I have a key hidden on the outside of the van in case I forget and lock my keys inside-------again. (Hasn't happened in over 8 years.................)
Old Jan 1, 2019 | 07:38 PM
Texas Mad Man
JWA:
Thank you for the information. I may be disconnecting in the future.
nookiemonster55
Sep 17, 2011 08:24 PM
rhino_160
26
Jul 2, 2011 10:29 PM
Bluegrass F250
Apr 28, 2011 11:11 AM
m42
1997 - 2003 F150
Jul 6, 2006 06:36 AM
JAYW
1997 - 2003 F150
Apr 4, 2006 02:18 PM
