HEY ALL, my 2000 navi all the sudden started the following: the door chime, when you leave the key in the ignition and open the door, continues to chime even when i take the key out. i can't figure it out??? the lights and everything shut off, just the chime continues. any ideas? thanks
man i''ve got almost the same issue with my 97 expy........Keys off ignition door chimes....sometimes it even chimes when door is closed and no keys on ignition!
It's weird i am thinking might be door trigger bud......in meantime let me know wut u come up with lol might help me....
from what i can figure so far it is not in the door switch being all the lights shut off when i close it, and that switch in the door controls the lights and everything all in one unit, i believe. i do think the problem may be in the ignition where you slide the key in. i think there is a "pin" or something the key presses on when in the ignition, and then releases when you remove the key. i believe the "pin" is sticking. any other ideas??? thanks
I've got an 02 Expedition and this happens to me often (but not always). The issue with mine is that the ignition thinks the key is still in, meaning I can still turn it even with the key out (though it won't start due to security system). My solution is just to wiggle the ignition back and forth until it gets into the correct spot and the chime stops. I guess the true fix would be to correct the sensor that determines whether the key is in or not, but it's not a big deal for me so I haven't looked into it.
hey rhino just wanted to know, have you been able to solve issue or do anything with the switch? did you bought new ignition switch? i still got issues with my 97 expy and wanted to know what u've done to yours.....I noticed my issue is the same as yours now, i narrowed it down to the ignition switch...when i fumble it with no key.... the ding ding stops but when i slam door comes back on.....no idea....confused by now lol
My brother's 99 Crown Vic does the same thing. He takes the key out and the "ding...ding...ding" continues. He just taps the steering column with his fist and it stops dinging.
